Hey Nvr2fist
Old Oct 12, 2005 | 07:47 AM
PlainRuss's Avatar
Member
Default Hey Nvr2fist
I have found the problem with your speaker, it's your CD's. I have removed all the Cher, Madonna, and that terrible rap CD that has Ray Charles mixed into it and burned them. It's all good now. Oh, and the ECM and TCM both have internal memory problems so I replaced them both and sent the old ones back to Auburn Hills.
Your welcome. =)
Old Oct 12, 2005 | 08:10 AM
Nvr2Fst's Avatar
Senior Member
Default bwahahaha....I put the rap music in there just for you
It happens on my Barry manilow disc alot also....It shouldnt rattle with the bass at the highest setting right???? :-)
Old Oct 12, 2005 | 08:12 AM
PlainRuss's Avatar
Member
Default I think it's really the loose screw between your ears. =P
I will be doing some good surgery to your engine for your oil leak.
Old Oct 12, 2005 | 08:32 AM
Nvr2Fst's Avatar
Senior Member
no crap? what be da problem?
Old Oct 12, 2005 | 08:36 AM
PlainRuss's Avatar
Member
Default Your I heart Martha Stewart t-shirt is caught up in a seal.
Cam adjuster gaskets are leaking, very common. It's not a huge ordeal, just need to pull the cams out, drop on the floor, kick them, etc.
Old Oct 12, 2005 | 09:30 AM
Nvr2Fst's Avatar
Senior Member
Default thank you kind sir...would you be kind enough to put my shirt in the trunk
I have been looking for that
Old Oct 12, 2005 | 09:37 AM
PlainRuss's Avatar
Member
Will do.
NickCowan
Apr 11, 2010 10:29 AM
mm
12
Nov 25, 2003 04:05 AM
spider_audi
Jul 18, 2002 10:29 AM
krimlan
Nov 18, 2001 12:35 PM
