Looking for a shop to check out my chip
Old Mar 22, 2007 | 05:58 AM
A4BoomerSooner's Avatar
New Member
Default Looking for a shop to check out my chip
Anyone know of a good shop in the Madison/Milwaukee WI area?
I am not against making the trip to Chicago. I am not familiar with any shops in the Chicago area either
Old Mar 22, 2007 | 06:27 AM
no.radar's Avatar
AudiWorld Expert
Default If Chicago--->
You cannot beat...<ul><li><a href="http://www.vfc-engineering.com/">Doug Hillmann.</a></li></ul>
Old Mar 22, 2007 | 07:30 AM
Cargasm2.7's Avatar
What do you mean by, "check out my chip"?
Old Mar 22, 2007 | 07:44 AM
New Member
Default Re: What do you mean by, "check out my chip"?
i guess it could be my turbo...
my chip doesn't seem to be functioning correctly.
but.. it could also be the turbo..
Old Mar 22, 2007 | 08:20 AM
New Member
I guess I don't exactly know what is wrong with my car.
the turbo kicks in at arounnd 4-5k rpm.. where as it use to kick in at 2-3k rpm.
the check engine light is on.
the dealership said it was an alarm cause by the chip..( of course they would)
i should have it hooked up to a vag-com and see what it says.
any ideas?
obviously, i'm not familiar enough with the engine technology to troubleshoot this on my own
Old Mar 22, 2007 | 10:05 AM
skabaru's Avatar
Default you need to find a reliable shop that does turbo work and get it checked out.
There is likely nothing wrong with your chip. Chips either work or don't for the most part, assuming it worked fine in the past.
you probably have a vacuum leak or a exhaust leak or an inlet hose leak or something.
Old Mar 22, 2007 | 10:29 AM
KenRK's Avatar
Default I'm sure any of the 3 tuning shops listed here could help
Click on the logo for more info on any of them.<ul><li><a href="http://www.audichicago.org/eventdetail.php?id=150">Here</a></li></ul>
Old Mar 22, 2007 | 11:09 AM
New Member
Default could it be the clutch?
possibly an issue with the clutch slipping?
 Michael S. Palmer
Old Mar 22, 2007 | 11:31 AM
skabaru's Avatar
Default if the clutch were slipping, you would be driving, it would start excel, then as full boost hit
as you swung into boost, the clutch would start slipping and you would lose power.
Sounds like your power onset it later in the rpm range, correct? that doesn't sound like a slipping clutch really...
Old Mar 22, 2007 | 11:37 AM
Mike@PNS's Avatar
My guess is that your plumbing leak theory is probably correct.
SilverB6A4
23
Nov 18, 2005 04:20 AM
Raullopy
Nov 15, 2004 06:26 PM
A4inAZ
Dec 19, 2002 08:57 AM
Marc
Feb 25, 2000 07:40 AM
Gatsby
Sep 11, 1999 05:58 PM
