Is it possible to fix 2 piece wheel barrel without removing center piece?
Old Apr 4, 2007 | 08:29 AM
PR0XUS's Avatar
New Member
Default Is it possible to fix 2 piece wheel barrel without removing center piece?
One of my wheels came defective from the factory (barrel geometry was not perfect <a href="http://s38.photobucket.com/albums/e146/proxus/?action=view¤t=dpe_outofround.flv"> » VIDEO</a>), and I shipped it back. Manufacturer offered to fix it but in the same time they want to keep the center piece and put it back once barrel is fixed and straight.
Well....I'm not a wheel expert but those 2 piece wheels are welded, and I assume that in order to fix the barrel, you would need to disassemble those pieces (unweld the center)
If I'm correct, how safe and possible is that. Unwelding and welding the same piece could degrade the strenght of the wheel I guess [confused]
Up to date manufacturer and dealer are very responsive and helpful but I want to be 100% sure that I get quality product.
<img src="http://i38.photobucket.com/albums/e146/proxus/DPE_07vs_inside.jpg">
<img src="http://i38.photobucket.com/albums/e146/proxus/DPE_07vs_front3.jpg">
Old Apr 4, 2007 | 08:43 AM
Scott D.³'s Avatar
Default The barrel and teh center are held together by the hex bolts...they are designed to come apart and
be re-assembled. You should be fine, they will just replace the entire barrel with a new one...That's actually what is welded so they won't be returning to you anything that they have re-welded.
Old Apr 4, 2007 | 08:54 AM
PR0XUS's Avatar
New Member
are you sure that bolts are holding to the barrel? It doesn't look like on the picture.
Old Apr 4, 2007 | 09:33 AM
Scott D.³'s Avatar
Default if the bolts are not on a flange are they just there for cosmetic purposes????
If they are not bolted to the barrel and the center is actually welded....insist on new wheel!
Old Apr 4, 2007 | 09:53 AM
WindyCityS4's Avatar
That looks like a wheel made in 2 pieces, but welded into one. The bolts look like they are for show
Old Apr 4, 2007 | 10:38 AM
Matt_DTC...noTT's Avatar
New Member
You are hired...report monday 8:00 sharp!!!
Old Apr 4, 2007 | 06:49 PM
Scott D.³'s Avatar
belive me...as sucky as my jobs been lately you may have a deal!!!
ThreeTTwo
Jan 8, 2007 11:46 AM
rowl
May 11, 2004 01:51 PM
SameerP
Feb 17, 2002 11:26 AM
Crisqo09 T.O.
Dec 16, 2001 09:03 AM
