just got done flushing the brakes on the Porsche, then.........Crud
Old Apr 9, 2007 | 11:14 AM
40v-V8's Avatar
Member
Default just got done flushing the brakes on the Porsche, then.........Crud
flushed the system with ATE super blue dot 4, should be ok right?
<img src="http://i28.photobucket.com/albums/c213/acpeeps/IMG_4889-1.jpg">
<img src="http://i28.photobucket.com/albums/c213/acpeeps/IMG_4890.jpg">
Old Apr 9, 2007 | 11:22 AM
Press's Avatar
Fear the Miata!
should be fine
Old Apr 9, 2007 | 11:27 AM
bradford's Avatar
Junior Member
Are you asking if the snow will affect your brake fluid?
Old Apr 9, 2007 | 11:39 AM
40v-V8's Avatar
Member
Default no, the snow started just when I buttoned the system up, I am worried about putting
DOT4 in a DOT3 brake system, I can't remember, can 4 go into 3, but 3 not into 4?, or the other way around
Old Apr 9, 2007 | 11:40 AM
Press's Avatar
Fear the Miata!
i put dot 4 in the suburban...it's only a dot 3 system
Old Apr 9, 2007 | 12:14 PM
WindyCityS4's Avatar
DOT 5 is the "bad" stuff.
Old Apr 9, 2007 | 12:19 PM
40v-V8's Avatar
Member
Default thanks,
your a pal, and thanks for the ride at ABCC, learned a lot
Old Apr 9, 2007 | 12:51 PM
Press's Avatar
Fear the Miata!
Default look out...."pal"
<center><img src="http://www.areavoices.com/wrestling/images/thumbnail/kmac.jpg"></center><p>
 Michael S. Palmer
Old Apr 9, 2007 | 12:55 PM
40v-V8's Avatar
Member
Default so I thank a friend for teaching me new lines at a track, and I'm a kiss ***
whatever
Old Apr 9, 2007 | 12:57 PM
Press's Avatar
Fear the Miata!
lol
