IL emissions testing question re B5 S4 with gutted downpipes and relocated O2 sensors...
So is there anything I need to do in advance? Other than warming the car up to get the cats hot I mean.
Also, I'm in Grayslake in Lake County, so is Waukegan about the only place to go?
Thanks.
Brian
1. Check engine light is illuminated when the ignition is on.
2. It goes off with the engine running (no codes).
3. Readiness code is present....it needs less than a few hours to get this.
So I am saying you can set readiness in as little as a 1/2 hour if you know where to go in vag, how to initiate the test in vag, and the car decides to cooperate.
You can take an ECU that has readiness passed and pop it in 3 blocks from the testing center and you'll pass.
