Doing some DE events, but do not want to go BBK.
Thanks!
Pat
2001.5 Audi S4 APR Stage 2 (Mine)
If you wanted to keep your stock brakes you need to put in some Motul 600 or 660 brake fluid, get a decent set of track pads (NOT hp+'s) probably Hawk HT10 or better and some spare rotors.
You'll cook the hell out of those brakes and probably have a couple of scares if you start getting really fast.
<img src="http://i125.photobucket.com/albums/p79/SpartanS4/IMG_1264.jpg">
You can't use full track pads on the street (well, you can, but the noise will drive you crazy and they don't so well when they are cold).
Flush your stock brake fluid and refill with something good like SpartanS4 says.
Real track pads are a must.
Hell even pooptech 332's are better than stock (somewhat) and those are like $1k used.
Your getting into an expensive hobby here. My honest advice since you won't get a bbk out of the box is to put in motul fluid with some HT-10 pads and go to an event. It will ge a good learning experince for you
loud
dirty
hard on rotors
they will hold up pretty well on the track but you'll fade them if you drive hard enough especially if you run track tires. on street tires you'll probably be ok
in my experience this is good duel use pad if there is such a thing. I tracked with them many many times and it usually worked out pretty well
on the other hand, why not just buy race pads and install them at the track? lots of people do this. you may want to bring an extra set of rotors jut in case
fyi the s4 is not a cheap car to track so be aware you'll be spending lots of money regardless
I did track events for several years on stock brakes w/ track pads and I eventually burned the caliper seals and could not get a firm pedal.
It also depends on your driving style. if you are smooth and easy on the brakes they should be ok with a decent pad. if they start to fade just don't slow down so much!
