< 16 F and A6 Brake and Tire Warnings
Old Feb 14, 2008 | 02:35 PM
mloiterman's Avatar
New Member
Default < 16 F and A6 Brake and Tire Warnings
My wife's A6 Avant goes crazy every time it goes below about 16F.
Both the tire pressure warning and the rear brake warning light go off and never shut up until the ambient temperature goes above 17 or so.
Is it worth bringing in (semi-common problem), or are they just going to start swaping parts?
Old Feb 14, 2008 | 05:34 PM
ZCD2.7T's Avatar
Default I'm guessing that the car is an '05 or newer? If so, wrong forum. Try C6 forum:
Not that we don't want to help, but I'm actually not aware of anyone active on this forum that drives a C6 A6....
Sad, huh?<ul><li><a href="https://forums.audiworld.com/c6a6/">https://forums.audiworld.com/c6a6/</a</li></ul>
Old Feb 15, 2008 | 07:09 AM
spartanS4's Avatar
Default Have you checked your tire pressures? When it gets really cold...
Your pressure drops in your tires and can set off the low pressure alarm. It's happened in my trailblazer before and they were down a few psi from what it should be. Took it being 2 degrees outside though.
No clue on the brake pad sensor issue. If you can see that there is plenty of life left I would just ignore it.
Sorry if you already knew this, I thought I would give you my experience!
Old Feb 15, 2008 | 07:27 AM
Nvr2Fst's Avatar
Senior Member
Default tire psi will drop 1 psi for every 10 deg drop in temp. Im guessing the brake issue is temp
related also, but doesnt hurt to call the dealer just to be safe
280BlackPearl
A6 (C8 Platform) Discussion
Dec 28, 2018 03:08 PM
agjil
A6 (C7 Platform) Discussion
47
Nov 26, 2014 05:59 PM
BlueSander
VAG-COM Discussion
Nov 7, 2009 07:33 PM
05whtaudia6
Brakes Discussion
Feb 3, 2009 12:13 PM
mloiterman
Feb 15, 2008 06:22 AM
