Just put my DTS in my new allroad, I forgot just how effective it is!
Old Feb 11, 2004 | 05:44 AM
Ex-PzKW Cdr's Avatar
Member
Old Feb 11, 2004 | 07:19 AM
Cobalt03's Avatar
Default Putting up my hand (clearly a newbie)......
What is a DTS? A search revealed lots of discussion of which is best, mounting point issues, road height disucssions etc mostly on the A4/S4 board it looed liked, but not a single explanation of what it is/does etc. So, I'll bite, what the heck does it do and why do I need one? I assume (like most things I need, it voids my warranty) thanks
Old Feb 11, 2004 | 07:38 AM
happy allroader's Avatar
Default The AWE Tuning Drive Train Stabilizer (DTS) eliminates transmission shakes?
Additional brace for manual transmissions inside the engine compartment. Check out the AWE site for more info.
I didn't know until I "googled" 'DTS AUDI'.<ul><li><a href="http://www.awe-tuning.com/pages/gallery/awe_dts/index.cfm">http://www.awe-tuning.com/pages/gallery/awe_dts/index.cfm</a</li></ul>
Old Feb 11, 2004 | 08:10 AM
veloAR's Avatar
Default Are any modifications to the undercarriage required, or is it "plug and play?"
I seem to remember something about trimming or grinding exhaust braces. Also, the consensus seems to be that additional "road noise" is experienced. What noise, exactly? (rattles, creaks, or just plain tires/tranny/engine noise?)
Old Feb 11, 2004 | 09:58 AM
HPH's Avatar
HPH
Some kind of shadow with a tongue is hiding your top pic.
Old Feb 11, 2004 | 10:59 AM
dan farmer's Avatar
Senior Member
Yup, it's great! No more stirring a bowl of oatmeal when shifting.
Old Feb 11, 2004 | 11:08 AM
dan farmer's Avatar
Senior Member
Default Here's the deal.
I put on a DTS last week, so I'll answer for the ex-tanker. There is a small but noticable increase in structure-borne drivetrain noise. It's not vibration you feel, it's noise you hear. Mostly it's gear whine, and it's not bad. But it is there. The only mod required is sawing off the edge of a protective collar on the downpipe, where it goes over the cross-brace. The cross-brace will do the protecting, so the collar isn't needed. Clearance to the cross-brace *is* needed. AWE's instructions show the mod and describe the tools needed.
HTH-
-df
Old Feb 11, 2004 | 04:35 PM
Member
Default Did you adjust the front snubber? Mine has been dead silent on both cars.
There are slight variations inn the cars and sometimes you need to adjust the snubber as the DTS slighly raises the trans. And now that AWE has the adapters, no more kludging something.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 11, 2004 | 04:38 PM
Member
Default As I was the first allroad with one, I can atest to the fact that the only issue is
grindng the bumpers. I believe the noise issue is caused by snubber needing adjustment afterward. See above.
Old Feb 11, 2004 | 05:11 PM
dan farmer's Avatar
Senior Member
Default I had no idea. Got a link to more specifics?
For what time period should I STFA?
Thanx-
-df
