What is that 1-1/2" square grill 1/3 up the passenger side only B-pillar?
Old Feb 15, 2004 | 08:20 PM
MachineMan's Avatar
Default What is that 1-1/2" square grill 1/3 up the passenger side only B-pillar?
It looks similar to a plastic speaker grill and is light grey in my black interior. Could this be the interior temperature sensor? Odd place for it if it is. I thought it might be some kind of access plug but then again there is no corresponding grill in the driver's B-pillar.
Old Feb 16, 2004 | 09:31 AM
Dr.quattro's Avatar
Maybe the speaker/mic for the hands free kit?
Old Feb 16, 2004 | 10:23 AM
MachineMan's Avatar
No, its on the passenger B-pillar (adjacent to passenger's right elbow)
Old Feb 16, 2004 | 10:36 AM
kimer12345's Avatar
New Member
a temp sensor is the only thing I could figure... haven't tested it though.
Old Feb 16, 2004 | 11:31 AM
ShowMeData's Avatar
Default Pic? I don't see such on my 01
Though there is one on the driver's side, not the passenger.
Old Feb 16, 2004 | 12:07 PM
Rhoomba's Avatar
Default not in my 01, either.
not sure if this would matter or not, but - for the record - I have the optional side/rear airbags.
I would hazard a guess that it's a part of security system (like the 4 sensors at the top of each B-pillar).
-Rhumble
01 allroad
98 VFR
Old Feb 16, 2004 | 12:50 PM
MachineMan's Avatar
Default Lean the passenger seat back and look on the B-pillar right across from the passenger's elbow
USA spec left drive 2003 ar
Old Feb 16, 2004 | 01:14 PM
Chris C's Avatar
25 Year Member
Internal motion sensor.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 16, 2004 | 02:37 PM
MachineMan's Avatar
Can't be that as it looks at the seat edge plus never heard of that option on ar
Old Feb 16, 2004 | 03:58 PM
kimer12345's Avatar
New Member
Default Yes, my 02 has motion sensor...
..try looking on your B pillar, driver's side, inside the door frame, where your trunk release button is. The other button just above (or below) that is your motion sensor button. If you press that before you get out & lock your car, it will cancel out the motion sensor.
So if you leave Fido in the car with the windows down while you drop off a fedex (uhh...not that I've done this of course! ha), and you lock the car, and Fido moves, the alarm goes off unless you press that button when you get out.
The sensitivity of this sensor is something you can also adjust with your VAG-COM tool.
