Instrument Cluster
I haven't traced the schematic dia for this car yet, so I can't say how it works, but it probably involves a unique Audi connection harness (ar to trailer).
Extra current drain for trailer indicators activates it. Primary reason is as a warning if trailer light fuses.
Have 2 of these on my tractor for 2 trailers
Should there be a trailer wiring harness and connector somewhere at or around the rear bumper of my 03 ar?
Do you know if the ar electrics will operate with tailers that have separate turn signal and brake light filaments and also with those that use a common filament for turn and brake lights?
I've owned several Audi/VW diesels, all older tech, but good low speed torque none the less.
Would like to see 3.0 diesel mentioned as part of the 06 A6 propaganda in an ar. I'd buy it.
However, I also noted that it only comes on when I press the turn signal light half way doing a lane change.
I thought it meant turn signal blinking once?
