Audi could learn from Acura
Yet, you can read this forum and see the same issues over & over that I have had on my 2002 allroad...rotors warp every 10K, shifter could be better, O2 sensors go bad, wipers that clog with snow, oil leaks and OE tires that handle poorly and are useless in snow. (Plus lag issues for the tip drivers)
Maybe Honda/Acura actually reads their dealer's repair orders and owner forums.
Jim
GM had the same problem for years with their trucks. In the last generation they finally got smart and spent the money to upsize the front rotors and use 4-wheel discs - problems solved, but it increased the mfg cost of the vehicle (and improved safety).
Your last statement is bogus: Audi absolutely is to be held responsible to their customers for every bit of the car. They may be able to push some of the pain back upstream to a vendor if the problem is due to vendor quality control, but that is between Audi and the vendor and in no way reduces Audi's responsibility to their customer.
I bedded the pads in on my wife's allroad and we are nearly at 30k miles without any problems.<ul><li><a href="http://www.stoptech.com/whitepapers/warped_rotors_myth.htm">Read this</a></li></ul>
