MIKTIP - Need 12v professional's opinion on cooling issues I experience - running hot, no elec. fans
Old Sep 16, 2003 | 08:58 PM
DINA's Avatar
Junior Member
Default MIKTIP - Need 12v professional's opinion on cooling issues I experience - running hot, no elec. fans
'95 90 / 12v -
I've noticed that in stop and go driving, my temp guage goes a bit higher than I'd like it to, one bar hotter than the thick 'normal' bar. The thermostat has ~40k miles on it and is about 3 years old. The coolant is Dexcool which I did about 2 months ago (70/30), although that replaced green coolant. The guy I bought it from was running green, apparently, b/c he didn't know any better. At any rate, ever since I changed it, the engine SEEMS to run hotter. I did a radiator flush (10 minute flush) since I recall reading that doing a flush in between is best; was this not the right thing to do?
Yes, I believe my guages are right-on.
Also, I don't think I've ever heard the cooling fans cycle on w/o the a/c running. Is there a switch or something that usually goes bad to kick the fans on at high temps?
I drained the Dexcool out of it this evening and filled it with Super Cleaner, the type of radiator cleaner you leave in for a few operating hours. I was (unless told to do otherwise) going to drive it a bit tomorrow morning with the cleaner cycling, then drain it in the afternoon, replace the t-stat, then fill it back up with Dexcool.
*A switch for cycling the fans- do these go out, and if so, where can I find it, and or, how can I test it?
*T-stat- where is it, is it hard to change, with only 40k should the old be changed?
*Isn't Dexcool the same as Audi's recommended coolant?
*If you had a gallon of coolant, how much would you pour-in before adding water, with the 12v?
Thanks!
Matt
Old Sep 16, 2003 | 09:16 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Re: cooling issues
<center><img src="http://pictureposter.audiworld.com/6607/coolpic.jpg"></center><p>&gt;(70/30)????
70% Distilled water, 30% coolant?
&gt;a radiator flush (10 minute flush) since I recall reading that doing a flush in between is best&gt;
The V6 engine block "cannot" be drained by draining the rad. You must "drain" the system completly, by, 1 draining the radiator, 2 draining the engine block. The block has a drain, on the bottom near the trans/gearbox.
This is the "best" and complete way to drain old coolant.
&gt;Yes, I believe my guages are right-on.
Audi instruments leave much to be desired......
&gt;I don't think I've ever heard the cooling fans cycle on w/o the a/c running. Is there a switch or something that usually goes bad to kick the fans on at high temps?
Yes there is a switch. Located in the radiator, passenger side bottom. There's also a relay.
&gt;I drained the Dexcool out of it this evening and filled it with Super Cleaner, the type of radiator cleaner you leave in for a few operating hours. I was (unless told to do otherwise) going to drive it a bit tomorrow morning with the cleaner cycling, then drain it in the afternoon, replace the t-stat, then fill it back up with Dexcool.
"follow the directions on the bottle!"
Best thing to do, if its suspected bad, replace it.
Depends on the brand of t-stat which was installed? Who installed it, and if its installed correctly?
"Any" anti-freeze which is "phosphate-free" you can run in your Audi. Any color, as long as its "phosphate-free".
You mix the distilled water, and coolant, before you pour it in your car. Its recommended to mix 50/50. Or 60/40, with 60 being the distilled water.
Another thing to make sure, is to bleed the air from the system. V6's are bad on retaining air. Thats why Audi installed 2 bleed screws. Air does not transfer heat! It must be bled from the system, or can cause all sorts of problems! ;O)
gateway
Sep 10, 2015 04:15 PM
blacks42000
Aug 6, 2009 06:46 PM
tehA8PIMP
May 10, 2007 01:24 PM
smurfy
Jan 26, 2003 03:34 PM
