My ladies's 93 90CS has started to pop when she turns the steering wheel to the left....
Old Sep 18, 2003 | 05:05 AM
quattromano's Avatar
Default My ladies's 93 90CS has started to pop when she turns the steering wheel to the left....
it isn't the CV joint, it's new. Could it be the link rod or the balljoint? Anybody have this problem before?
Old Sep 18, 2003 | 05:20 AM
Audi-90sGuy's Avatar
Junior Member
Default Re: Where is the pop coming from?
Could be a loose strut nut as well, shock nut is not tight enough and is letting the shock jump inside the strut.
Old Sep 18, 2003 | 07:14 AM
Nah, it ain't the strut. it's coming from the lower area.
Old Sep 18, 2003 | 08:22 AM
Junior Member
Default Re: could be ball joint then, depends on....
how much you need to turn the wheels to get the knock.
Old Sep 18, 2003 | 09:17 AM
TurboEnvy52's Avatar
Default Re: Just one pop?
If it is i have been having the same problem just havent had time to look at it.
Keep us informed i would like to know what to look at if you figure it out.
-JIM
Old Sep 18, 2003 | 04:48 PM
goldringer's Avatar
Default Re: My ladies's 93 90CS has started to pop when she turns the steering wheel to the left....
I had the same noise in the same situation. Try the CV-Boot. Easy $135 fix.
Old Sep 19, 2003 | 12:32 AM
AlanBDahl's Avatar
Junior Member
Default Mine does that too
Mine does the same thing and I'm wondering if it's either a) something in the steering or b) related to the new Koni shocks I had installed a few months ago. I remember several people saying at the time that a small amount of oil should be added to the strut before installing the shock. The installation guy thought that was nuts and didn't do it but now I am not so sure.
VikingDiesel
Apr 11, 2009 07:15 PM
JMS-Four
10
Mar 30, 2007 06:30 AM
mr-epic
May 3, 2004 01:54 PM
90quattroman
Mar 14, 2002 08:29 AM
mm
Nov 5, 2001 04:06 PM
