Cleaning motor
Old Sep 18, 2003 | 07:23 PM
N X B 3's Avatar
Default Cleaning motor
I have taken the head off my car andf there are 2 cyl flooded with coolent i asume its a bad head gasket b4 i put it back on i need to know what i should use to get rid of all the build up on the pistons. thx, anthony
Old Sep 18, 2003 | 07:25 PM
repeater's Avatar
Scrape, carb clean, shop vac or compressed air to blow out.
Old Sep 18, 2003 | 07:35 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Absorbent rags, cloth, or paper should do the trick. Also.......
make sure you drain & change the oil & filter, before running the engine for the first time.
Then after allowing the engine to idle, for ashort period of time(first startup after repairs)
change the oil & filter again.
You might want to get a non-synthetic brand oil for this.
It will help clean out the blocks internals. ;O)
Old Sep 18, 2003 | 07:38 PM
kung_fu_4.2's Avatar
Member
Shop VAC
RagtopDay
TT (Mk2) Discussion
Oct 31, 2007 01:51 PM
coolHluke
Oct 2, 2003 05:54 PM
Pizzicato
Canadian Discussion
Apr 2, 2003 05:22 PM
Keyna
Sep 27, 2002 12:04 PM
formerly dennisA4
Aug 31, 2002 05:15 PM
