Which transmission people use with the 10vT swap?
thanks
The 01A has a much lighter, quicker action, which I like moreso than the 016's.
The only other choice would be an 01E. Figure on spending at least $3k to get a 6spd version, plus who knows how much on the new shift linkage and such, as well as new front axles.
I wouldn't do a thing, except maybe put new syncro's into your 01A if you have grinding or if its difficult to get into gears (but first check all mounts, and do a drain/flush/fill of tranny fluid).
2) Is it possible to it the 5kTQ tranny (don't know the name) when doing the swap? or is it the 016 that you told me.
Could always run a 4kq's 016, but I don't think its ratios would help out much. Plus, any 016 needs a 4kq shift mech. grafted in, not a straight swap.
The 01E comes as a 6spd, that will really drop the rev's down for cruising. Source an S2 or RS2 shift mech. and some other bits to run one. Probably at least $4k plus shipping to run a complete 01E. I'd just have a shop shorten the existing prop.
When/if I break my 01A after the 10vt swap is complete, I'll probably run a 6spd 01E.
I'll stick with my tranny and gona rebuilt. how far are you?
