HELP!!!!!!! PS pump started whining this morning and foaming out the cap - dlr. told me brake fluid
Old Sep 20, 2003 | 06:49 AM
DINA's Avatar
Junior Member
Default HELP!!!!!!! PS pump started whining this morning and foaming out the cap - dlr. told me brake fluid
This morning (but not last night when I shut the car off) when I started my '95 90, the PS pump was whining quite a bit. After driving for a block, I opened the hook b/c it was so damn loud and found that there was fluid foaming out of the PS fluid reservoir's cap. It only foams (expands) when you turn the wheel, otherwise, it's fine.
The pump looks OK, sounds OK, but whines when you turn the wheel, assumedly b/c of the foaming.
I THINK it's b/c when I called the dealer the other day about what type of PS fluid to use, they told me to use DOT 4 brake fluid. So I did; I used DOT 4 Prestone brake fluid. IS THIS my problem? I put in, maybe, 4 ozs...?
HELP!!!!!!!!!!!!!!!!!!!!!!
Old Sep 20, 2003 | 07:05 AM
DINA's Avatar
Junior Member
Dealer told me to use brake fluid to top off PS fluid - right / wrong?
Old Sep 20, 2003 | 07:20 AM
MasterB's Avatar
Member
Default I wouldn't do it
<ul><li><a href="https://forums.audiworld.com/9080/msgs/102608.phtml">https://forums.audiworld.com/9080/msgs/102608.phtml</a></li></ul>
Old Sep 20, 2003 | 07:48 AM
cuatrokoop's Avatar
Default Doesn't your car use Mineral Hydraulic Fluid???
All '88-95 cars do, IIRC. If so, you MUST USE THE PROPER FLUID. Otherwise, you will damage the system. The dealer told you completely wrong! DOT4 is NOT compatable with MHF. Go and ask for G002000 "oil for hydraulic system and power steering". There are also some compatable fluids from Mercedes, Jaguar (Castrol), Febi Bilstein, Lucas, etc.
Old Sep 20, 2003 | 07:56 AM
Brdman*'s Avatar
WRONG!
Old Sep 20, 2003 | 07:59 AM
TabulaRasa's Avatar
Default You need to suck that **** out.
And put in the proper fluid.
Old Sep 20, 2003 | 08:11 AM
DINA's Avatar
Junior Member
Default Called the dealer - their mgmt. is freaking out b/c their advice may have f'ed my car...
Both their Parts AND Service departments told me to use DOT 4 in place of the Pentosin. But a few minutes ago I called my guy in parts who told me "HELL NO, DON'T USE BRAKE FLUID!" I said OK, so your guy in parts is now responsible for my damage. They're DELIVERING 2 FREE liters of Pentosin and I'm flushing the system in a few mins. If the problem is still there, they KNOW I'll take action against them. What else?!
For future reference... Laurel Audi in Westmont, IL.
Yay... bend me over.
Old Sep 20, 2003 | 09:59 AM
DINA's Avatar
Junior Member
Default Cripe. I'm leaking everywhere, and not in a good way.
There is PS fluid leaking from EVERYWHERE and ANYWHERE possible. Looks like it's the dealer's turn to elect what needs to be done next b/c I sure as hell am not busting my hump over this!
Any suggestions or recommendations while battling this issue?
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 20, 2003 | 10:41 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Your car uses this-
<center><img src="http://img.eautopartscatalog.com/live/M210034367.JPG"></center><p>
Not brake fluid.
You will need to drain &amp; flush the steering system.
The correct stuff can be gotten here-<ul><li><a href="http://catalog.eautopartscatalog.com/pmc/wizard.jsp?partner=pmc&amp;year=1995&amp;make=AU&a mp;model=90--002&amp;category=M&amp;part=P%2FS+Fluid">http://catalog.eautopartscatalog.com/pmc/wizard.jsp?partner=pmc&amp;year=1995&amp;make=A
humphrey_2.7
Mar 17, 2008 11:43 AM
The Red October
Dec 10, 2007 10:43 AM
bes4000
Jan 10, 2005 10:06 PM
Stoney
9
Sep 16, 2004 09:53 AM
escargot
Jan 26, 2004 12:58 PM
