2.2turbo conversion!! Help!
Old Sep 20, 2003 | 07:26 AM
slimbo's Avatar
New Member
Default 2.2turbo conversion!! Help!
Hello!
I'm having a little trouble, and wonder if you might help?
I have a '88 Audi Coupe, and I am currently trying to drop in the lump from a '83 A200.
My coupe has the 2.2 lump, the replacement is the 2.2 Turbo.
The trouble is, the exhaust manifold and wastegate foul on the o/s trackrod, and the turbo itself hits the headlight support.
Have you tried this conversion before? Or could you help in any way??
Many thanks
Simon Read
Old Sep 20, 2003 | 07:56 AM
cuatrokoop's Avatar
Default Re: 2.2turbo conversion!! Help!
You need to modify the downpipe and the tie rod. Tie rod needs bent, and the d.p. needs cut apart, and welded in a better orientation.
As for the turbo fitment issue, you'll need a different exhaust manifold and downpipe to go with that. The MC/KG/JY/KH codes would be far better.
BTW, the '83 10vt motor isn't that great. I'd actually NOT use it. Its not intercooled for one, and two its barely more powerful than an NF/NG motor. Three, the turbo is oil only, no water cooling.
Old Sep 20, 2003 | 08:41 AM
slimbo's Avatar
New Member
Thanks for the info!
What would you recommend I do with my KV engine, to improve power? Is the turbo completely useless??
Old Sep 20, 2003 | 09:14 AM
slimbo's Avatar
New Member
Default Re: Do they smog test where your from?
Emissions are tested on the MOT, the donor car passed its MOT, so I guess its okay.
Old Sep 20, 2003 | 09:33 AM
slimbo's Avatar
New Member
Ok, so what would a 2.2turbo lump with wiring loom etc 120k miles, be worth if I sell it?!
Old Sep 20, 2003 | 12:26 PM
Audi Ryder's Avatar
New Member
Default For one, you should have gone with the MC mill swap.
The MC mill goes in without a problem, and is more powerful than the mill you're putting in the car. It doesn't fit properly because it wasn't meant to. Go to my page for details, and next time leave it to professionals;-)
<a href="http://boykinracing.us/Conversions.htm">Click here</a>
Old Sep 20, 2003 | 01:38 PM
cuatrokoop's Avatar
For your car, I'd try to source one of these motors, from these years (do not go older if the UK checks those things, some States in the US do):
From the 100/200 series cars:
'88-91 MC code, 165hp
'88 KG code, 182hp
'88-91 1B code, 200hp
'88-91 2B code, 190hp
From the Turbo quattro Coupe (aka quattro)
'88 WR code, 200hp
'88 GV code, 200hp
'88-90 WX code, 162hp
'88-90 MB code, 200hp
You'll need to check into clutch &amp; flywheel issues too. Your clutch assembly is a 228mm, and the turbo motors you should be using are all 240mm. You could probably run a flywheel from the donor car, as well as its clutch disc and pressure plate. Same transmission input shaft IIRC, so the disc should match up with the splines w/out problem.
You have the right idea in running a turbo motor instead of the KV. Just didn't choose wisely ;-) Also, since your Coupe is an '88, its a type85 chassis. Our cars are type89/8A/8B/8C/8G, all newer than yours. However, the 10vt swap is still very similar. The 4k/CGT forum may be able to better answer specific questions, however I know a thing or two, as do a few others on here...
cuatrokoop's Avatar
Default Re: For one, you should have gone with the MC mill swap.
Ok, for one, he's in the UK. Two, who calls a motor or engine a mill?
He isn't limited to just using an MC, he's got MANY options for a 10vt over there (see my other post).
Also, you don't have to be a professional to do an engine swap! I'm not a professional mechanic, but I've only had to farm out a small handful of things to a machine shop for my engine swap. I applaud what you have done and are doing, don't get me wrong, but the nature of this forum isn't conducive for a shop (on the wrong side of the Atlantic no less) to try and drum up business. Besides, your site doesn't give insight at how to go about swapping a 10vt in place of a 10v or 20v.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 20, 2003 | 01:45 PM
cuatrokoop's Avatar
The particular motor you have, since its the non-watercooled turbo setup w/no intercooler, probably 400USD w/wiring if its nice, so what is that, 250GBP?
Old Sep 20, 2003 | 09:16 PM
repeater's Avatar
Default My take on this........
You mention, "I applaud you for what you have done and are doing." Ummm, what HAS he done? What have we seen aside for a Mercedes V8 swap that's the basis for his only work, aside from a 10vt 80 swap with components spray painted without removing them? I analyze this as the following, and maybe I'm wrong, or maybe I'm right, but it's been bugging me so I'm spewing..
1. Just because someone "claims" to be a "professional" - doesn't mean they ARE a "professional". As you have indicated, most true "professionals" are actually dedicated smart mechanics, like yourself.
2. I agree that J Boykin's company intentions appear to be good, after all, starting a business is, in fact an American dream, right?
3. I have also, to this day, not seen any other engine swaps via pictures, documentation. So, can you tell me why I should give someone 7500.00 to swap an Audi engine with no proof they've ever done one...Like say... the 2.7TT swap listed? Hmmmmmm. Case in point, last week Ryder asks if the 2.7TT swap is even feasable in a B3/B4 (answer being no, unless massive plasma cutting is involved), now suddenly, according to the website, they can do it? Hmmmmmm.
My advise, and here, repeater is being serious....
There are people who have good business skills and people who have good skills in what they are in business for. Some have both. This is rare. They are called professionals. You can see where this is going. If I were you Audiryder, I'd tone down some of the auto-rhetoric that you spew - alot of people on here see right through the bull****. I think you're head is in the right direction - but I have still to see a post from you that actually displays any sort of general Audi technical knowledge that you hold yourself in such high esteem about.
Perhaps I'm wrong? I dont know - maybe you can prove it to me. It's nothing personal, in fact, I admire your motivation for success in being an entrepreneuar. Hopefully sonner than later you'll learn that spewing a punch of rhetoric is pointless when trying to obtain customers and respect - there's a fine line to walk, as most will tell you.
