Idle Problem - its not ISV ...more
Old Sep 21, 2003 | 11:52 AM
red90q's Avatar
Default Idle Problem - its not ISV ...more
Determined my idle problem is not ISV. Will be replacing O2 sensor and have vac test done. What else could I do to remedy problem...idle bops up and down from 1000 - 1400 when engine reachs normal operating temperature.
Old Sep 21, 2003 | 02:21 PM
Audi Ryder's Avatar
New Member
Default Re: Idle Problem - its not ISV ...more
Check the PCV valve, or the intake hose...any leaks here cause irradic idle.
Old Sep 21, 2003 | 02:30 PM
repeater's Avatar
Ding! Ding! No PCV valve on a 7A 20V.
Old Sep 21, 2003 | 04:08 PM
Audi Ryder's Avatar
New Member
Default Why would I know that?Do I look like I drive a 7A?
Just a suggestion for a solution to a common problem. For most cars, irradic idle is caused by one of two things. Vacuum leaks, ISV or PCV. Somewhere air is leaving the system. I see you'll be on my back, so I'll make sure I'll be watching what I post;-) Thanks Repeater, can I call you Tim?
Old Sep 21, 2003 | 04:13 PM
repeater's Avatar
Default Well I just thought an Audi tuner would know that.
PS, And you don't drive a 7A, you install it or drive the car that it's in ;-)
Old Sep 21, 2003 | 04:16 PM
Audi Ryder's Avatar
New Member
That;s right...driver's only
Old Sep 21, 2003 | 04:43 PM
Merkin's Avatar
AudiWorld Expert
good ol vac leak/o2 solution
Gearcon
Sep 30, 2013 07:14 AM
meathead
Feb 17, 2013 06:12 AM
tjscanlon
Aug 11, 2004 02:43 PM
TomServo82
Misc. Models Discussion
Apr 5, 2000 09:03 AM
Bob Petruska
Nov 14, 1998 11:07 PM
