94 Audi 90 CS - Catalytic converter replacement
Old Sep 21, 2003 | 10:01 PM
steveturoff's Avatar
New Member
Default 94 Audi 90 CS - Catalytic converter replacement
Greetings,
How difficult is it to replace the cat converters on a 94 Audi 90 CS? Does it require welding? I went to Midas and they wanted $1700, which sounds ridiculous to me. Thanks, Steve.
Old Sep 21, 2003 | 11:48 PM
el skolnick's Avatar
Junior Member
Default That is rediculous. Just order some cats from catco or summit racing and pay the labour to cut out
and replace
Old Sep 22, 2003 | 12:28 AM
TabulaRasa's Avatar
Default Yup.
Replace BOTH the cats with Catco cats from Summit Racing. They are only about $70/ea.
The Midas estimate sounds about right if they are using an OEM factory part. No sense in spending that $$ though.
You can remove the cat by unbolting it.
I chose to cut it off because it clogged my exhaust and basically made the car undrivable. Used a Dremel tool and took me forever. I got air tools and a angle grinder now.
Old Sep 22, 2003 | 07:23 AM
The Puke's Avatar
Junior Member
Default You can't simply unbolt the cat and replace with a Catco converter...
... the factory catalytic converter (on my 1995 90q, at least) included most of the downpipe. So, to replace with a Catco coverter, cutting and welding would be necessary. It was very difficult for me to find shops that would do this; I ended up going with some OEM-ish replacements from Stebro, IIRC. They were pretty damn expensive, too, though.
Old Sep 22, 2003 | 07:25 AM
Junior Member
really? I was able to pay my local speedy muffler shop to do it
Old Sep 22, 2003 | 03:51 PM
New Member
Default Re: really? I was able to pay my local speedy muffler shop to do it
What year is yours?
Old Sep 22, 2003 | 08:49 PM
The Puke's Avatar
Junior Member
Default Yep...
I checked about 4 shops in the area, both independent and chains, and nobody would do it, especially since I had bought the catalytic converters from someone else (that's half their profit)... so I ended up returning them and getting my regular shop to get a set because I needed to get the 90 back on the road.
Old Sep 22, 2003 | 08:50 PM
Junior Member
'88 but it's the same no matter what car it is... you're just paying for the labour.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 22, 2003 | 09:47 PM
lukin36's Avatar
New Member
My shop did it for 30 bucks, Just go to a small muffler/welding shop not the big chains maybe.
Old Sep 23, 2003 | 06:59 AM
New Member
Default What about doing it myself?
OK, what if I buy the OEM parts, for example, http://www.catalyticonverters.com/AU9048959395.html
It says the parts just bolt in. Do I need any special tools to do this? Are there any seals and/or gaskets that need replacing?
Thanks. BTW, I really appreciate the advice everyone has provided. Nice to have a forum with such quick, accurate responses.
