Rattling/Ticking
Old Sep 22, 2003 | 01:35 PM
lukin36's Avatar
New Member
Default Rattling/Ticking
Hi,
Well I can't seem to find the source of the problem. But while I'm driving my car it always make this loud annoying rattling/ticking noise, the harder I accelerate the worse. I thought it was the CAT but its not that and it doesn't sound like its coming from the lifters. It only does it while I'm driving though, when I try hitting the gas while Idling it won't make the noise. Any ideas on what else it could be?
Old Sep 22, 2003 | 03:33 PM
nbevins's Avatar
Member
Default What year? Heat shields tight?
Part of my old cats are stuck in my muffler which makes a rattling noise...
Old Sep 22, 2003 | 06:14 PM
KarcherK's Avatar
New Member
Default i have the same problem....
try the spray shield thing behind the rotors, slam the door a couple times or hit each tire to see if it rattles then, thats how I found mine and sure enough one was lose. also does the noise get worse when your next to another car or next to a wall?
Old Sep 22, 2003 | 09:41 PM
lukin36's Avatar
New Member
Default Yeah it gets worse next to a wall or car, probably just because sound bouncing off though
Thanks for the help though, Ill check the spray shield?? Are they something you replace or bend into shape or what? Thanks
Old Sep 22, 2003 | 10:51 PM
KarcherK's Avatar
New Member
Default I posted the same problem awhile ago....
and I was told just to tighten the bolt but to get to the bolt you have to take the rotor off.
Old Sep 23, 2003 | 03:39 PM
DavinMB's Avatar
New Member
Default Re: What year? Heat shields tight?
i agree, totally check the exhaust heat shield. i had the same problem. try just starting from park with the door open and going a few feet, but hit the accelerator with some force so it's pretty loud. if it sounds like it's coming from beneath, it's most likely the heat shield.
Pete5587
Mar 28, 2008 09:36 AM
atlquattro
Mar 5, 2008 09:10 AM
shwndh
Aug 29, 2006 09:30 PM
Spannerhead
12
Dec 27, 2004 07:03 AM
sirdavid
Mar 2, 2000 12:58 PM
