head work
Old Sep 22, 2003 | 07:16 PM
N X B 3's Avatar
Default head work
as many of you know i am putting my motor back togather. b4 i go and do that i was thinking of hetting my head done buy autotech. they call it the Smallstem Zylinderkopf. the link is http://www.autotech.com/cylhead.htm is this somkething that will give me some extra power? I know alot of you thinkn its a rip off cause the price but the question is will i notice a diffrence?<ul><li><a href="http://www.autotech.com/cylhead.htm">http://www.autotech.com/cylhead.htm</a</li></ul>
Old Sep 22, 2003 | 07:33 PM
MrPolak's Avatar
New Member
CHOKE! $1300? Dude, G-grind cam, double-downpipe, oversize throttle body.. sweet+ le$$
Old Sep 22, 2003 | 08:27 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Here's the deal! ;O)
You need to modify every component, starting from the airbox, to the exhaust tips.!
Doing the heads, alone, with no other mods, will yield "minimal gains".
If you port &amp; polish the heads, then you need to P&amp;P the intake manifold. Followed by the throttlebody, and modify everything both upstream(air) and down stream, to gain the maximun effect from your efforts.
Ported heads perform better with a set of cams.
If you do the heads, with no other mods, your wasting your money.
Its all about fuel, fire &amp; air.
Modify components to allow in more air, your raise the fire &amp; fuel. However to allow more air into the engine, it must be made to escape(exhaust) better as well.
See where this is all going?
Plus dont expect any "huge" gains from a "naturally aspirated" engine. You'll be lucky to get 30hp, after spending several thousand dollars! ;o)
Old Sep 22, 2003 | 08:47 PM
N X B 3's Avatar
Default where can i get this stuff for a 4cyl?????
i plan on doing exhaust work also. I like all the ieads you have but..... i have a 4cyl there is not alot of stuff out there for it so if you know where i can get it just let me know.
Old Sep 22, 2003 | 08:51 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Get 4 banger stuff here-
Secret- Vw 4 cylinder watercooled, very simular to Audi water cooled 4! ;O)<ul><li><a href="http://www.tttuning.com">http://www.tttuning.com</a</li></ul>
Old Sep 23, 2003 | 05:45 AM
oddBALL's Avatar
Junior Member
My struts didnt give me any hp lol : ) i spent 500$ there
Old Sep 23, 2003 | 06:56 PM
MrPolak's Avatar
New Member
Default You could....
... buy a good used VW Corrado G60 engine with the G-lader. Rebuild the G-lader if needed ($650) and proceed to motor about with 158 HP under the hood. A few light mods and you've got 200 HP.
Well, the G-60 conversion would not be that easy because of the electronics, but it sounds good!
BoostFrenzy
1.8T Discussion
Oct 17, 2007 05:20 AM
VW-Quantum-Man
12
Jul 19, 2006 12:26 PM
quattrokid98A4
12v V6 Discussion
Apr 17, 2006 04:08 PM
Afterthought
13
Oct 30, 2005 11:45 AM
zamicus
Sep 17, 2004 10:31 AM
