To dremel, or not to dremel?
Old Sep 22, 2003 | 08:53 PM
Hokie - STI avant's Avatar
Default To dremel, or not to dremel?
I'm thinking of doing the "MikTip" lower headlight trim mod. I'm not too good with a dremel though (just got it 2 weeks ago).
I don't want to mess up the trim piece... so what should I do? Also, how is the wire mesh connected in the back?
Mike
Old Sep 22, 2003 | 08:54 PM
TabulaRasa's Avatar
Default Just take the trim piece off.
If you don't notice an improvement, put it back on.
If you do notice an improvement, but want it to look nicer, dremel.
Old Sep 22, 2003 | 08:55 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Be careful, the plastic likes to "grab" the dremel bit! ;O)
My wire mesh is epoxy'd inplace. ;O)
Old Sep 22, 2003 | 08:56 PM
Merkin's Avatar
AudiWorld Expert
plastic? mine is metal, i toasted couple bits
Old Sep 22, 2003 | 09:00 PM
TabulaRasa's Avatar
Your one piece typ89 trim is metal. On the B4 it's plastic.
Old Sep 22, 2003 | 09:32 PM
UrSoccer_mobile®'s Avatar
Default Here's what I would do!
start by drilling holes on both ends - enough for a hack saw to fit (you might want to get a smaller blade) then hack it all the way across to the other end. Don't worry about keeping it straight because your dremel will take care of that and so as the finishing touches.
Then glue the mesh screen!
Old Sep 23, 2003 | 05:38 AM
oddBALL's Avatar
Junior Member
Default True true Tabularasa
What does a 1995 B4 90 wiegh?
Old Sep 23, 2003 | 06:57 AM
gdrien's Avatar
New Member
Default How do you shape the mesh?
Do you bend it over a form? It looks professional, and I'm concerned that I won't be able to duplicate that.
Also, where'd you get the mesh? Is it left over from a grille replacement?
Thanks!
 Pouria Savadkouei
 Michael S. Palmer
WMi_S4
10
Feb 3, 2009 05:35 AM
eggdog
Audi allroad
Dec 30, 2007 03:10 PM
Blewtoon
Nov 6, 2007 04:39 PM
