Idle still F@#$ED
Old Mar 7, 2004 | 08:55 AM
red90q's Avatar
Default Idle still F@#$ED
Well I'm back from cleaning and lubing that frikin ISV. Idle is still up and down like a YO-YO. Used a can of carb cleaner trying to look for vac leaks aswell. I guess I'm off to the "Stealership" to have them look at it.AHAHAHAHAHAH !!! (just venting a bit, sorry)
Old Mar 7, 2004 | 08:56 AM
white90+hibredS4's Avatar
Member
do you have a cone filter installed?
Old Mar 7, 2004 | 09:01 AM
red90q's Avatar
Default Re: do you have a cone filter installed?
Yes but that was installed long before the problem started to occur
Old Mar 7, 2004 | 09:11 AM
Member
well what is the temp outside?
Old Mar 7, 2004 | 09:15 AM
red90q's Avatar
0 degree C - but it started in the Summer - gets up to 40 with humidity in T.O
Old Mar 7, 2004 | 09:58 AM
Member
Default when its warm outside does it idle better? i had the same problem...
when i changed back to normal the heating tube brought in more heat to the engine. try switching back to the regular set up and see if it works.
Old Mar 7, 2004 | 10:15 AM
lyonelll's Avatar
Junior Member
Same here,bounces around couple of times 800-1400 rpm,cone
Old Mar 7, 2004 | 11:39 AM
YucatanAudi's Avatar
Re: The cone can get oil on the MAF sensor over time - mess things up....
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 7, 2004 | 11:58 AM
red90q's Avatar
How can I clean the MAF without damaging it ??
Old Mar 7, 2004 | 12:45 PM
absolutcq20v's Avatar
Default Re: Check the TAB screw or for collapsed crackcase breather hose...
...my CQ had a terrible idle bounce until I replaced the breather tube with the updated one and replaced the cracked TAB screw o-ring with a new one. This was back in 2000 and it's been rock-solid since. Good luck.
