Wierd headunit problem. Audi or Panasonic problem?
Old Mar 7, 2004 | 10:02 AM
Daedalus's Avatar
New Member
Default Wierd headunit problem. Audi or Panasonic problem?
I reciently bought and installed a Panasonic CQ-HX1083U.
<img src="http://catalog2.panasonic.com/webapp/wcs/stores/images/models/cq-hx1083u.jpg">
My friend and I got it in and set my presets and everything sounded and looked great. Then I put an MP3 CD in and when it started up, I only had the front 2 speakers working. Eh? I pulled out the CD and set the headunit back to tuner, and all 6 speakers worked. Hmm. Thought it was just the CD, so I put in a regular music CD. Same issue! I was pretty pissed off.
Do you think this is a headunit problem, or some wiring problem. I'm leaning towards a Panasonic problem because why would everything work in tuner but not in the CD mode?
Any ideas? Please help.
Old Mar 7, 2004 | 10:31 AM
repeater's Avatar
Default Re: Wierd headunit problem. Audi or Panasonic problem?
Sounds like a headunit problem. If the speakers work on the radio sets and not on a CD, I would think that would be a headunit issue. Now, if the speakers never worked on any setting, radio AM/FM, or CD, then it's a wiring issue.
Old Mar 7, 2004 | 10:34 AM
RxFX101's Avatar
cool lookin headunit..but your problem sounds like its comin from ur cool lookin headunit!
Old Mar 7, 2004 | 11:29 AM
white90+hibredS4's Avatar
Member
headunit go exchange it
Old Mar 7, 2004 | 11:50 AM
escargot's Avatar
Ask the audio forum.
Old Mar 7, 2004 | 12:37 PM
absolutcq20v's Avatar
Re: def. headunit..i had an old sony that did that with tapes (remember tapes?)
Old Mar 7, 2004 | 12:47 PM
MFZERO's Avatar
Default did you wire anything to the power antenna lead on the headunit?
you may have put the wire that goes to power for the rear speakers there. which would explain radio on = all 6 &amp; cd = front 2
Old Mar 7, 2004 | 02:58 PM
nurseman's Avatar
New Member
Default Re: did you wire anything to the power antenna lead on the headunit?
why would it be a poewr to the remote antenna. IO ask because I have the same problem?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 7, 2004 | 05:00 PM
MFZERO's Avatar
Default some radios stop sending power to the antenna when ............
you go to a mode other than radio
Old Mar 7, 2004 | 05:50 PM
pro_mtn_biker's Avatar
Junior Member
Default what year audi? the rear speakers are amplified on some models
I had to rewire my rear speakers, and if you want to keep the tweeters you will need a crossover for each speaker.
