which relay will shut off the high speed radiator fan - 1994 90S
Old Mar 8, 2004 | 11:28 AM
white951's Avatar
New Member
Default which relay will shut off the high speed radiator fan - 1994 90S
My car just started the constant jet engine radiator fan speed when the car is running. The water pump was changed 30k miles ago by PO. I pulled all the related fuses and relays under the hood. Jet is still going. I pulled the knee panel off and started pulling some relays. No good. Didn't pull them all because some were hard to get to. Need some help here. Not sure what to do.
Old Mar 8, 2004 | 11:36 AM
zeems's Avatar
Default I had a bad relay #214 (?) that was above the knee panel...it made my fans run even with key out.
You really have to reach up in there to get those relays/fuses out.
Old Mar 8, 2004 | 01:01 PM
white951's Avatar
New Member
MIKTip - Any idea?
Old Mar 8, 2004 | 01:30 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Allow me to consult the wiring diagrams. ;O)
The Bentley wiring diagrams say, relay 18, in the relay panel above your left knee.
Or the RH, upper most relay.
But this depends on wheather you have manual or digital climate control. Manual or automatic transmission.
Old Mar 8, 2004 | 01:49 PM
white951's Avatar
New Member
manual climate. auto tranny
Old Mar 8, 2004 | 01:54 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Same, relay 18. The control relay differs in the relay box under the hood.
Old Mar 8, 2004 | 04:11 PM
white951's Avatar
New Member
Default The relays in the knee panel are 3 digit relays, not two.
So are you saying the relay to pull is #18 under the hood. I allready pulled the relays under the hood that indicate they have something to do with the radiator fan and the fan kept going like a jet. The relays under the knee panel say 236, 336....??
Old Mar 8, 2004 | 04:51 PM
zeems's Avatar
Default Is there no #214 in the knee panel? I'm pretty sure that's the one I replaced.
Or it could have been #203.
Why don't you just pull each one out one at a time??
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 8, 2004 | 05:01 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default 18 indicates their location.
<center><img src="http://pictureposter.audiworld.com/6607/relays.jpg"></center><p>
Old Mar 9, 2004 | 10:13 AM
white951's Avatar
New Member
Its #217. Position 18. way in there behind others. Thanks MikTip!!
