Type 89 vs. B4 dash
Old Mar 8, 2004 | 12:17 PM
n0e's Avatar
n0e
New Member
Default Type 89 vs. B4 dash
Hi,
I know the two 'look' the same, but are they made and put together the same?
The reason I ask is my type 89 coupe's dash is extremely squeeky in contrast to my B4 80 which is nice and silent.
Also the edge where the dash meets the windscreen is loose where i guess one of the clips should be.
...in fact, the B4 interior seems like a much better quality than the in the coupe.
Any idea's ??
Cheers
J
Old Mar 8, 2004 | 12:35 PM
cuatrokoop's Avatar
Default I think your Coupe got beat on.....My CQ's interior is quite nice, only noise is from the rear hatch
catch/latch, which is a known common problem. The dash of the B3 and B4 are virtually identical IIRC.
Old Mar 8, 2004 | 12:36 PM
allYourBaseRtehSuck's Avatar
Junior Member
could be age/mileage diff
Old Mar 8, 2004 | 12:37 PM
white90+hibredS4's Avatar
Member
maybe just older like allyoubase says
Old Mar 8, 2004 | 12:41 PM
Audicted's Avatar
Default Is that what the darn squeaking is about? It's driving me nuts.
There has got to be a way to fix it. I can't wait till spring, gonna tear that sucker apart.
Old Mar 8, 2004 | 12:56 PM
n0e's Avatar
n0e
New Member
Default Re: Is that what the darn squeaking is about? It's driving me nuts.
Yeah it's driving me nuts too.
The Coupe is a 1992 and the B4 is a 1993....the B4's got more mileage.
Think the only remedy is to rip the thing apart
Old Mar 8, 2004 | 12:59 PM
TabulaRasa's Avatar
I just keep feeding those two rubber mounts on the hatch with silicone spray, quiets it right up.
Better solution would be removing the backseat and going with a roll cage for more rigidity though CQ is noticably floppier feeling than the B4 90.
Old Mar 8, 2004 | 01:24 PM
cuatrokoop's Avatar
No, it isn't noticably "floppier" than a B4 sedan...The sedan only has two reasons to be stiffer. One is the front tower brace. The other is the rear parcel shelf. Neither of those two add extreme amounts of torional rigidity. Both can be replicated. The front is EASY and cheap. The brace ends are $15/ea from the dealer. Need welded on though. Rear, shouldn't be too hard to add a brace.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 8, 2004 | 01:56 PM
TabulaRasa's Avatar
B4 90 > CQ in rigidity IMHO.
Old Mar 8, 2004 | 04:19 PM
Hidshadows's Avatar
I *think* there was a technical bulleton that talked about a shim.
