Opinions on these EBC Sport Grooved rotors from Tirerack?
<img src="http://pictureposter.audiworld.com/52171/ebc_rotors_goldblack.jpg">
standard slotted rotors, you could feel the slots pass over the pad when you brakes hard...
i like standard drilled...
To date, I have not yet cracked any drilled rotor I have owned.
I've always owned a good "name brand" rotors, like Brembo & Zimmermann.
Its true, drilled rotors can crack, but this is something associated with severe usage, or severe over-heating.
On a street driven car, driven primarily on the street, drilled rotors will do fine.
Place same 4000lb car on a track with OEM sized, drilled rotors, and you might overheat the rotors, and they could crack?
Its not a "guarentee" they will "always" crack, but even non-drilled rotors can crack, if over-stressed. ;O)
<img src="http://www.stoptech.com/press_releases/thunderhill_closeup_rotor.jpg" border="0">
Slotted.
<img src="http://www.mouthbreather.net/images/rotors_small.jpg" border="0">
OEM
-Mike
