Electrical problems ?
Old Mar 8, 2004 | 01:43 PM
carlosdsantana2000's Avatar
New Member
Default Electrical problems ?
Hello dear Audi fans!
I have an 1990 Audi 90 which is having the following (electrical ?) problem.
When I turn the ignition key one position, the battery, parking and brake light were on but slightly blinking.
After couple of action on the ignition key (without starting the engine), now the water temperature and oil pressure lights are not on anymore and I hear a stange sound (buzz) behind the dash board.
Thank you for your help.
Old Mar 8, 2004 | 01:48 PM
YucatanAudi's Avatar
Default Re: Bad ignition switch, probably. It only costs $25 and isn't too hard to change.
You do not need to replace the key cylinder. Only the switch behind it.
Do a search on replace ignition switch and you will find lots of posts.
Strange electrical problems frequently are traced back to there.....
Old Mar 8, 2004 | 01:58 PM
Joe Sixpack's Avatar
Default Re:Electrical problems? might be...I'd check this first as it easy to see/feel if there's a problem!
<ul><li><a href="https://forums.audiworld.com/9080/msgs/140357.phtml">https://forums.audiworld.com/9080/msgs/140357.phtml</a</li></ul>
Old Mar 8, 2004 | 04:08 PM
white90+hibredS4's Avatar
Member
most probably Ignition switch like yucatan says
Old Mar 8, 2004 | 11:06 PM
New Member
What about the starter itself ?
For more than 3 years now, I used to hear a mechanical sound (metal friction like) when starting the engine.
Old Mar 15, 2004 | 01:10 AM
New Member
Default It was not the ignition switch !
I've replaced the ignition switch and the problem is still there.
I've also removed one by one each fuse to isolate the problem without success.
Any idea ?
Before starting the engine, there is no water level light, the "oil pressure" buzzer is on all the times + when I start the engine, the battery light is weak and slightly blinking.
Also, for weeks now, I don't have anymore rear motion lights.
Thank for your help.
Old Mar 15, 2004 | 05:27 AM
Default Re: It was not the ignition switch ! did you check this?
<ul><li><a href="https://forums.audiworld.com/9080/msgs/168504.phtml">https://forums.audiworld.com/9080/msgs/168504.phtml</a</li></ul>
Old Mar 16, 2004 | 09:39 AM
New Member
Default This dashboard problem drives me crazy !
Quick recap: (Audi 90; 1990; 5 cylinders; great car)
1) I turn the ignition key on (without starting the engine) =&gt; the battery light is abnormally blinking
2) I turn off and on the ignition key again (without starting the engine)=&gt; the water and brake lights do not lit up; the battery light is abnormally blinking; and the oil pressure buzzer starts after few seconds. (since then, when I turn on the key, this same problem occurs)
3) The engine starts but the battery light remains blinking (low light)
4) I changed the ignition switch =&gt; no change
5) I removed one by one all the fuses and the connector underneath the dashboard =&gt; no relation with the problem
6) The car has a ground problem somewhere with the reverse light but when I disconnected the reverse light connector, the same dashboard problem is still there
Is is possible that the dashboard itself is the problem ?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 16, 2004 | 10:26 AM
Default Re: It is true that bad wires / burnt bulbs in the rear lights can cause strange problems up front.
Have you checked all the wiring and bulbs to the lights? Especially the trunk wiring, where it flexes.
Also, Check fuses 12 &amp; 14 closely.
And check this link too:
http://www.sjmautotechnik.com/instrument.html
Problems like this do occur:
Dash Lights inoperative? License plate bulbs burned out? On some of the 5000 vehicles, a strange thing occurs if both of the rear license plate bulbs get burned out, the dash lights may not function at all. It has been rumored that opening up the glove box may get the dash lights working temporarily.<ul><li><a href="https://forums.audiworld.com/9080/msgs/143053.phtml">check this link also:</a></li></ul>
Old Mar 16, 2004 | 10:35 AM
Default Re: ETKA shows a voltage regulator in the gauge cluster?
<center><img src="http://pictureposter.audiworld.com/41300/voltage2.jpg"></center><p>Might be worth a once over to see if anything is out of place.
Check the trunk wiring first, i had a short in the gauge lights and it was the wires in my trunk dude, check them out like i said 9 days ago.
