Need ops here guys. What is the general feeling about drilled Brembo rotors frnt &back ....
Old Mar 9, 2004 | 07:35 AM
quattromano's Avatar
Default Need ops here guys. What is the general feeling about drilled Brembo rotors frnt &back ....
for a car that is never tracked. Namely my CQ.
Is it a waste of money? Should I just stick with the regular hats for the car?
Old Mar 9, 2004 | 07:57 AM
Dewey316's Avatar
New Member
Default Re: Need ops here guys. What is the general feeling about drilled Brembo rotors frnt &back ....
what is your puprose for wanting drilled rotors. truth be told they only benifit from drilled rotors now, is the 'bling' on my track car, i always run solid rotors, the extra mass aids in temp. contorl. with the brake pad compounds of today, the gas build-up is almost nill. drilling the rotors helped in the 70's, but today is all marketing hype, and looks. for the BEST performance, a good direction vain solid rotor is your best bet.
Old Mar 9, 2004 | 08:15 AM
UrSoccer_mobile®'s Avatar
if you don't track your car, I would say no need for it unless it's for show. If you want mad braking power, you might wanna go the "MikTip" way system but then again if and only if you are planning to track your car..
Why not go with the slotted ones? helps brake pads wear evenly..and cheaper too.. IMO
09mehashaw
Audi allroad
9
Jul 8, 2011 11:08 AM
esanmiguel
Nov 1, 2007 01:05 PM
Dano_SL
A4 (B7 Platform) Discussion
Mar 29, 2007 02:00 PM
NJWilliam
Brakes Discussion
Mar 24, 2007 02:55 PM
DARK CLOUD S4
May 22, 2002 03:13 PM
