I think maybe I found the vacumm leak or clog.. My ?? is, is this the problem for my high idle?
1. Idle Air Control (IAC) valve -N71- sticks, is hard to move or does not operate
- Failures because of contamination in the intake manifold; because of this, IAC valve rotary slide valve surface scratches possible.
- Cleaning with compressed air unsuccessful.
- When removed or disconnected, only limp home slot can be seen. The control edge lies on the opposite side.
- The limp home slot of IAC valve -N71- must not be widened by tools inserted from the outside.
- The visible surface of the rotary slide valve must not be machined mechanically.
- Check IAC valve Page 24-34 (internal resistance: 7-10 ohms)
2. Throttle Body (TB) faulty
- Air leak at stage 2 leads to incorrect learned values. DTC 01257 (IAC valve) can be stored, read DTC memory.
- Malfunction in the ECM or mass air flow sensor is unlikely.
- Difficult to recognize with On Board Diagnostic, since usually there is no constant air leak value.
-Perform basic setting of the engine Repair Group 01.
- Using "Read Measuring Value Block" function 08, display group 004, display fields 2 and 3, check whether specified values lie in the lower or upper limit range. If the values lie outside or very close to the tolerance limit, see Repair Group 01.
- Throttle Body can only be checked visually for sticking, e.g. after removal.
3. Throttle Position (TP) sensor -G69- and Closed Throttle Position (CTP) switch simultaneously faulty
No acceleration enrichment.
Throttle position sensor incorrectly adjusted, has tolerance problem and/or break in wiring on resistor area (misfiring/bucking, poor throttle response).
Throttle position sensor remains continuously on wide open throttle. (Fuel consumption too high)
- Read DTC memory and check "Read Measuring Value Block" function 08, display group 002 with VAG 1551 Repair Group 01. With continuous accelerator pedal movement/throttle opening this value must also increase continuously.
- Check wiring connector.
4. Engine Coolant Temperature (ECT) sensor -G62- out of tolerance
This results in a function of the oxygen sensor control. Engine too rich or too lean.
- Check resistance Repair Group 28.
- Check to see whether values displayed are realistic - "Read Measuring Value Block" function 08, display group 001, display field 2 Repair Group 01.
