Repost - MY CQ dash lights are out/ NOT the fuse? Any ideas??
Old Mar 10, 2004 | 08:21 PM
stormchaser's Avatar
New Member
Default Repost - MY CQ dash lights are out/ NOT the fuse? Any ideas??
All lights are out at night . Clock, System Check light, work but are alway lit even during the day. The thing that does not work is any lights that would come on with activating the headlights. Could it be my headlight switch? wires in the hatch?
Old Mar 10, 2004 | 08:25 PM
cuatrokoop's Avatar
Default Re: Repost - MY CQ dash lights are out/ NOT the fuse? Any ideas??
Had an aftermarket HU that was connected improperly (dimmer wire attached, learned you can't connect it for some reason), blew a fuse, no dash lights as you said. I had even checked all the fuses too. Took one of our old master mech's to say "yup, it was a fuse, found it and replaced it." So, you may want to double check the fuses, check your lic. plate lights and that fuse, glove box light and fuse, etc.
Old Mar 11, 2004 | 03:09 AM
New Member
Will Check fuse again. U might be right since I just replaced a headlight bulb with bright sylvania?
maherbeemer
Aug 14, 2013 08:22 AM
5000Q86
Jul 7, 2008 09:15 PM
GrussGott
Apr 9, 2005 02:37 PM
james2.8QMS
Nov 23, 2003 01:11 PM
sagjohnson
Nov 4, 2003 07:14 PM
