MY CQ Airbag light stays on for 4-5 minutes after starting? What up with that?
Old Mar 20, 2004 | 08:45 PM
stormchaser's Avatar
New Member
Old Mar 20, 2004 | 09:31 PM
SLAB's Avatar
Default airbag fault...$hit's broke...
airbag module, spiral spring, or P/S...
Old Mar 21, 2004 | 04:18 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default If it eventually goes out, you can probably reset it with VAG-COM and it will be OK
But it that doesn't work, you may have to spend some money.
Old Mar 21, 2004 | 06:22 AM
TurboEnvy52's Avatar
Airbag? What airbag?
Old Mar 21, 2004 | 09:50 AM
Bubuski's Avatar
US spec has air bag but not Canadian
Old Mar 21, 2004 | 10:51 AM
SLAB's Avatar
Default funny thing is, you cannot reset these things with anything...
they dont require resetting...each time the ignition is switched off, it looses memory...then back on, it performs the self test...
Audi has a specific airbag tester tool...but you have to pull out the center stack to get to the airbag module, and they will prolly charge through the nose to do that..
if it takes a solid 4-5 MINUTES to go off, then more than likely you have a wiring fault, or a dead module...
ive been there, and done that
Old Mar 21, 2004 | 11:52 AM
SCarGo02's Avatar
Default I know on B4s you can reset the airbag system/pull codes/etc. with the VAG-COM...
...I thought you could with some B3s/CQs too, no?
Old Mar 21, 2004 | 12:55 PM
SLAB's Avatar
nope! as far as i know, none of the B3's are like that
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 21, 2004 | 01:02 PM
I gots a US coupe with no Airbag, think it is just the earlier model before they were required
shazoo
Aug 18, 2023 05:39 PM
DAS4
Mar 9, 2011 08:49 PM
NW Avant
Dec 7, 2008 02:19 PM
IanManchester
VAG-COM Discussion
Sep 21, 2007 09:29 PM
Johnny Ballgame
May 15, 2005 08:37 AM
