What would everyone recommend doing at the same time as the timing belt?
Old Mar 21, 2004 | 09:49 AM
sidespar's Avatar
Default What would everyone recommend doing at the same time as the timing belt?
I know to do the water pump and thermostat, but what else?
Old Mar 21, 2004 | 09:52 AM
repeater's Avatar
Default Valve seals aren't a bad idea.
You've got the belt already off, might as well pull the cams and do the seals too, especially if you're having oil consumption problems. If not, then WP and Stat are fine.
Old Mar 21, 2004 | 09:58 AM
lyonelll's Avatar
Junior Member
any rollers and tensioners on 20V?
white90+hibredS4's Avatar
Member
with lyonell get the tensioner and serpentine belt
Old Mar 21, 2004 | 10:03 AM
foberg34's Avatar
No serp-belt on 20v, but do replace the v-belts
Old Mar 21, 2004 | 10:10 AM
lyonelll's Avatar
Junior Member
Oh yes,just replaced my alt belt-these three Should be changed with T-belt
Old Mar 21, 2004 | 12:13 PM
Hidshadows's Avatar
Default idler pully, coolant, water pump, crank/cam seals, V-belts, timing belt
You could do the snub mount while you are looking at it.
Old Mar 21, 2004 | 03:44 PM
sidespar's Avatar
v-belts? be specific.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 21, 2004 | 06:31 PM
Hidshadows's Avatar
Default Re: v-belts? be specific.
Alternator 054 903 137
A/C 034 260 849
Hydraulic Pump 035 260 849 C
01northernS4
May 31, 2006 10:37 AM
sparkster
Dec 15, 2002 08:37 PM
M.S.G. Homey
Jul 17, 2002 10:51 PM
atrak
Jul 17, 2002 04:21 PM
tfortag
Jul 10, 2002 04:38 PM
