I just put Rockford Fosgate5 1/4 in the rear.Connected to stock wiring.
Old Mar 22, 2004 | 08:21 AM
lyonelll's Avatar
Junior Member
Default I just put Rockford Fosgate5 1/4 in the rear.Connected to stock wiring.
Assumed green wire=+,brown=-.When I turn volume halfway they start cracking terribly.Should i run wires all the way from HU?
Old Mar 22, 2004 | 08:25 AM
quattro90S6's Avatar
Default you need an amp.....
the gama sends out a dead signal to the back door speakers, only the dash gets a live signal. I put 6.5 inch JL's in doors and have a pioneer amp in trunk.
Old Mar 22, 2004 | 08:35 AM
SCarGo02's Avatar
Default The stock wires are skinny line level grade, run some decent wires from your deck/amp to them.
This is assuming you're using an aftermarket deck. The stock deck/wiring uses a "common ground", only the O.E. decks like this. Aftermarket decks will sound like crap, or won't work at all unless you seperate the ground wires.
If you're using the stock deck, the speakers need to be amplified some how, the output on the deck is line-level (a signal meant to be amplified). If you're using an aftermarket deck, just use some decent wire and connect it to the speaker-level output on your deck.
Old Mar 22, 2004 | 08:44 AM
lyonelll's Avatar
Junior Member
Sorry,the one I had was from B3-Your B4 emblem is slightly different
|skolnick's Avatar
Can you please email me? I would like to ask you a question.
Old Mar 22, 2004 | 08:47 AM
lyonelll's Avatar
Junior Member
Default I tried 2 decks-both Sony,older one that came with car
plays until mid-level volume,newer one-cracking starts right away.Fronts are also RF-sound OK with both decks
Old Mar 22, 2004 | 08:57 AM
90/90Qs's Avatar
yes. Stock wiring is too small for anything except low level signal
Old Mar 22, 2004 | 08:59 AM
Wren90q's Avatar
Default Is this for your B3 or B4?
If B3, wiring to the back is really easy. I'm using the stock front wires and I ran new speaker wire along the driver's side under the carpet and through an opening behind the back seat into the trunk. Took about a half hour. Just have to loosen a few trim pieces on the B-pillar to get the wire under & remove the side-sills IIRC.
 Pouria Savadkouei
 Michael S. Palmer
lyonelll's Avatar
Junior Member
E-mail sent
Old Mar 22, 2004 | 09:00 AM
lyonelll's Avatar
Junior Member
B3
