Front brakes to rear
Old Oct 4, 2004 | 05:35 AM
elijahallen's Avatar
Default Front brakes to rear
Hi all, well the 90 Coupe to AAN S2 project is coming along slow but sure. The engine is back together and ready to go in and the 6 speed tranny is getting figured out. I used my S4 front hubs and Big Blacks with Porsche rotors and aluminum hats on the front and am thinking about putting the stock front brakes on the rear with S2 hubs. Has anyone done this? I realize it may be a little much but I hope to have the shop adjust the bias to allow this to work. Any experiance is appreciated.
Elijah
Old Oct 4, 2004 | 06:05 AM
CJ Miller's Avatar
Default Re: Front brakes to rear
Another issue to consider: will you have enough master cylinder volume? The porsche brakes may use more fluid than the g60s, and I'm sure the g60s use more fluid than the stock rear single piston brakes.
I think the shop will have to add an adjustable brake bias valve if you change the rear calipers.
I don't think it's worth the effort, myself. I'd consider ducting some air to the rear brakes, and good pads, but that's it. Rest is probably cosmetic.
Old Oct 4, 2004 | 06:06 AM
YumyJager's Avatar
Default Dude, just get your car working and in your hands.
I want to see posts from you telling us how much it rules ;-)
Old Oct 4, 2004 | 06:31 AM
Default I know, I just don't want to miss anything that will be a big PITA later...
I am also waiting on my tubular exhaust manifold and would like to get it on before the engine goes in but if not the RS2 manifold will have to do for a while.
Elijah
Old Oct 4, 2004 | 06:43 AM
4Driver4's Avatar
Tech Guru
Tech Guru
E- brake?
Old Oct 4, 2004 | 07:42 AM
NoNonsense's Avatar
is it completely necessary? i never use mine...
Old Oct 4, 2004 | 08:19 AM
tpierce's Avatar
Default you could also put UrS4 rotors and calipers in the rear
that way you keep the parking brake. Also, i believe you can use the rear calipers off of a B5 S4 with the Ur rotor, and the B5 caliper is aluminum, so it keeps the weight down, while keeping the parking brake. I believe the f/r bias is set by the block that the lines run to after leaving the MC, not totally sure though.
Old Oct 4, 2004 | 03:51 PM
YucatanAudi's Avatar
In most states, working E-Brake / Parking Brake is an inspection item - U fail if it doesn't work.
 Pouria Savadkouei
 Michael S. Palmer
Esquire6
17
Mar 16, 2005 07:14 AM
GARY CRUSE
Audi A3 / S3 / RS 3
Feb 2, 2004 05:56 AM
swichlaw
Mar 10, 2003 10:58 AM
HDClown
Feb 14, 2002 07:22 PM
White Coupe
Feb 5, 2002 12:15 PM
