CQ: Outside Temp reading shows 11 Fah/ -11 Cel - bad sensor?
Old Oct 4, 2004 | 08:59 AM
Snopyro's Avatar
Default CQ: Outside Temp reading shows 11 Fah/ -11 Cel - bad sensor?
My A/C doesn't seem to working anymore and the outside temp gauge button always shows 11 degrees Fah/ -11 degrees Cel. Is my temperature sensor/sender bad? If so, what part(s) and part numbers will I need? Also, the best places to buy these pieces from. Thanks!
Old Oct 4, 2004 | 09:24 AM
YumyJager's Avatar
Default The sensor is attached to the back of the grille.
Check to see if there is a break in the wire and the such.
Old Oct 4, 2004 | 10:42 AM
Hidshadows's Avatar
Default go to 20v.org
on that website under, problem/fixes and under the climate control section there are fault codes and sensor values that you can pull on the sensors.
There are two one near the grill and one near the air intake for the interior.
Just follow the directions.
Good Luck.
Old Oct 4, 2004 | 10:45 AM
Snopyro's Avatar
Default thanks, I always forget to look at that site before posting.
I'll check the resistors (hopefully, that's the problem and it will be a $2 fix).
Old Oct 4, 2004 | 11:40 AM
Hidshadows's Avatar
Default actually an even cheaper fix is to just pull one of the sensors
The engine bay has two sensors and will always read off the of the lower temperature one. If one is reading -10C and the other is 23C, then the -10C gets used. If you unplug the -10C one then the 23C is used.
jazz215
Jun 19, 2007 12:26 PM
kaynos
Sep 6, 2005 06:24 AM
Barnstormer
Mar 17, 2005 02:15 PM
410225
Jul 22, 2003 06:34 PM
