My B4/90 Sport Quattro 4130 chromolly adjustable racing sway bar end links are finally done...
Old Oct 4, 2004 | 07:23 PM
VAP's Avatar
VAP
Default My B4/90 Sport Quattro 4130 chromolly adjustable racing sway bar end links are finally done...
<center><img src="http://pictureposter.audiworld.com/711/adjlink5.jpg"></center><p>this may be the nicest they'll ever look considering the real estate they'll occupy for the next however long.
(stock F/R end-links are extreme right/left respectively in pic)
Tomorrow I'll corner-balance the 28mm/22mm F/R swaybars on a drive-on lift with me in the car w/helment so everything is balanced, weighted and car is nestled on its suspension same as I track the car. Later this week I'll go get a full day track time with the new wheels and R-compound tires to try and break/bend or otherwise makes these fail.
Just a hunch... bet I can't!
Old Oct 4, 2004 | 07:25 PM
cuatrokoop's Avatar
Default Re: My B4/90 Sport Quattro 4130 chromoly adjustable racing sway bar end links are finally done...
Those are quite nice, what did you end up coating them with? I caught you weren't going to paint/plate/anodize/powder coat them, so it really doesn't leave much left besides PlastiDip ;-)
Old Oct 4, 2004 | 07:26 PM
CvTech's Avatar
wow...B4/90 Sport Quattro 4130 chromolly adjustable racing sway bar end links..is a long name
Old Oct 4, 2004 | 07:30 PM
cuatrokoop's Avatar
Default Well, if you take the 2nd L out of chromolly (Chromium Molybdenum) it's shorter ;-)
Chromoly should only have one L, nit picky I know.....
Old Oct 4, 2004 | 07:32 PM
VAP's Avatar
VAP
Default very close to Plasti-Dip. I first sanded then Prep-Sol'd them and painted them with a....
duranodic epoxy. Then I used a 3M thick wall polyolefin adhesive-lined heat-shrink tubing. It's a very thick wall (.080") heat shrink tubing that conforms to minor bends/radii. When cured it sets to a very durable semi-hard, virtually indestructable finish. I've never heard of it being used for this kind of thing but just seemed like a very durable choice with a 500+ year shelf life in direct sunlight and incredibly abrasion resistant.
I'm thinking it'll outlive me but I plan on living forever so time will tell who wins ;-)
Old Oct 4, 2004 | 07:35 PM
CvTech's Avatar
ha ha...funny indeed!
Old Oct 4, 2004 | 07:39 PM
VAP's Avatar
VAP
Default I would prefer just "4130" tubing but very very few would know what I was referring to...
but here's a site I found when researching it that covers "all" the bases<ul><li><a href="http://www.aedmotorsport.com/Chromoly/4130.html#Streamline">4130 chrome moly molly chromemoly</a></li></ul>
Old Oct 4, 2004 | 07:48 PM
Blake@NWAutoSalon's Avatar
Those look really good, I wish everyday that you get a coupe...
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 4, 2004 | 07:51 PM
VAP's Avatar
VAP
already did that 15 years ago. If I ever go "back" to anything it'll be an AAN...
Old Oct 4, 2004 | 07:53 PM
pro_mtn_biker's Avatar
Junior Member
Default Re: My B4/90 Sport Quattro 4130 chromolly adjustable racing sway bar end links are finally done...
How were the tubes bent? Are those rod ends welded in or what is the spherical bearing threaded into? They look great!
