Cabriolet 4 bolt to 5 bolt switch..!!!!
Old Oct 5, 2004 | 09:34 AM
mum8les1's Avatar
New Member
Default Cabriolet 4 bolt to 5 bolt switch..!!!!
I have a gang of probs with my 95 cab.
first and formost ..I need to switch from a 4 bolt pattern wheel to a 5 bolt...
can anyone tell me what I need to do to make this happen the right way?
Old Oct 5, 2004 | 09:35 AM
quattro.pilot's Avatar
AudiWorld Expert
about $2grand <edit>
Old Oct 5, 2004 | 09:50 AM
|skolnick's Avatar
Default that's your biggest problem? search the forum for answers
<ul><li><a href="https://www.audiworld.com/search/">https://www.audiworld.com/search/</a</li></ul>
Old Oct 5, 2004 | 09:51 AM
NoNonsense's Avatar
Default you need the following:
- S2 hubs ($700)
- 4 wheel bearings ($150)
- S2 front/rear rotors ($250)
- 5x112 wheels and tires ($_____)
Old Oct 5, 2004 | 10:05 AM
Don@STaSIS's Avatar
Former Vendor
Default Cabriolet is FWD, so some 5x112 FWD hubs will be needed...
for the rear as S2 rear hubs are for the quats. Possibly a 5000tq rear hub will do the trick on a FWD such as the Cabriolet, but never jumped into that conversion.
How's the old 5 lug treating you?
Cheers,
Old Oct 5, 2004 | 10:06 AM
CrazyCab's Avatar
Default Why do you want to switch to 5 bolt
I understand its not the easiest bolt pattern to find wheels for, but they can be found.
Old Oct 5, 2004 | 11:52 AM
mum8les1's Avatar
New Member
Default Re: you need the following:
hey thanks man....anyidea where I can pickl all that stuff up?
Old Oct 5, 2004 | 11:53 AM
mum8les1's Avatar
New Member
Default Re: that's your biggest problem? search the forum for answers
actually it not my biggest prob...I cant get my damn right door open ..
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 5, 2004 | 02:25 PM
NoNonsense's Avatar
It is treating me fine! Just fine! Will you be around on Monday? i'll be driving thru
Old Oct 5, 2004 | 04:01 PM
Don@STaSIS's Avatar
Former Vendor
Should be around next Monday, though not certain if I'll be in the office or the garage.
