Brake lights & reverse lights not working properly
Old Oct 5, 2004 | 12:57 PM
LordMagnet's Avatar
Default Brake lights & reverse lights not working properly
My brake lights are brightly light up all the time when the headlights are on (light up like you have the brake pedal down), and my reverse lights don't work. I have replaced every bulb, and every fuse (under the hood). Anyone have any ideas? Thanks.
Old Oct 5, 2004 | 01:30 PM
OWDLVR's Avatar
Default Wiring. Trunk lid. 100%
Tonnes of posts if you search the archives.
-Dave
Old Oct 6, 2004 | 05:59 AM
MasterB's Avatar
Member
brake lights should still work, no? fog, int. trunk, reverse lights are affected by said wire, no?
Old Oct 6, 2004 | 06:30 AM
OWDLVR's Avatar
Default If I recall correctly...
The brake lights have a common ground with the rest of the lights in the trunk harness. Can really mess things up if the harness has split.
Old Oct 6, 2004 | 11:24 AM
CvTech's Avatar
I think Master B is right.
Old Oct 6, 2004 | 11:41 AM
OWDLVR's Avatar
Default The only reason why I think he isn't...
is because way back in the day when I mounted my reverse-light Hella I tapped into the trunk harness...and lost my brake lights.
But it's been so long since i did so, that I can't remember where the problem lay.
But yes, MasterB certainly could be right...
-Dave
mekcpa
A4 (B8 Platform) Discussion
May 29, 2017 01:05 PM
mekcpa
New Member Welcome Area
May 28, 2017 06:46 PM
sharknado
Q7 MK 1 Discussion
Feb 8, 2017 04:54 PM
audi/s/scott
Mar 1, 2009 01:35 PM
fitzroym
Mar 22, 2003 05:06 AM
