What would be involved in making a 1993 90cs FWD/5 speed into 5x112 bolt pattern?
Old Oct 5, 2004 | 07:21 PM
EvanUrS4's Avatar
Member
Default What would be involved in making a 1993 90cs FWD/5 speed into 5x112 bolt pattern?
I'm assuming the S2 hubs only work on a quattro? Is a FWD even possible without having hubs drilled custom?
Any info would be much appreciated... I have the stock lightweight 16x8's with brand new tires from my S4 sitting in the closet. I'd love to put them on my 90.
Old Oct 5, 2004 | 07:26 PM
SCarGo02's Avatar
You need to let your 16x8s out of the closet.
Nkugs90's Avatar
Default well...
You will need 4 new wheel bearings, 4 new brake rotors (5 x 112 pattern), a new set of wheels, and of course the front and rear hubs. I am not sure if your original calipers will still work but you should be able to find a set of rotors that will match up with your current brake calipers.
Old Oct 5, 2004 | 07:27 PM
EvanUrS4's Avatar
Member
I'm trying to =P They are shy...
YumyJager's Avatar
Default First step, sell the auto. Second stop buy a 5 speed.
Third step, just have the 5x112's re-drilled ti 4x108.
Old Oct 5, 2004 | 07:28 PM
EvanUrS4's Avatar
Member
New bearings wouldn't hurt - I'm aware of the rotor issue, have the wheels - Question is what hubs..
Old Oct 5, 2004 | 07:30 PM
SCarGo02's Avatar
Once they're out, I'm sure they'll love being shown off! ;o)
Old Oct 5, 2004 | 07:32 PM
EvanUrS4's Avatar
Member
What auto?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 5, 2004 | 07:46 PM
EvanUrS4's Avatar
Member
Also - Doesn't the B4-90 use the same rotors/calipers as the S4? I thought both were G60's over 10.9
Old Oct 5, 2004 | 07:49 PM
SCarGo02's Avatar
I was thinking the same thing...Yumy must have been drinkin'
