The Neuspeed 22mm bar does it come with the triangulating plates?
Old Oct 6, 2004 | 04:04 PM
Ghostfire's Avatar
Banned
Default The Neuspeed 22mm bar does it come with the triangulating plates?
If not where can I get a set. Also Does anyone have a pic of the rear axel with a upgraded swaybar on it. I am looking for a pic of the 93-95 quattro rear axel with or without the bar. I am trying to get a feel of what I will be up against when I try and make a Quattro rear bar fit a FWD 95 90. I dont want to crack my axel in doing it though. In the long run I want a 28mm up front and a 22mm in the rear. Thanks for any help!
Old Oct 6, 2004 | 04:19 PM
VAP's Avatar
VAP
Default for Audi B5 chassis cars any/all Neuspeed bars 19mm & over...
come with triangulated mounting kits if purchased new. Neuspeed lost their shorts in 2000 replacing rear sub drames on B5 chassis cars due to sway bar related cracks on 19/22mm bars.
Old Oct 6, 2004 | 04:26 PM
VAP's Avatar
VAP
Default oh wait, you're FWD. You wont be able to use the triangulated mounts....
or even the sway bar. You'd be better off researching/testing VW Golf rear sway bars than anything currently offered for Audi.
B2119's Avatar
And the B5 22mm bar will fit B4's?
Old Oct 6, 2004 | 04:28 PM
VAP's Avatar
VAP
no way, not even close as designed.
NoNonsense's Avatar
if you have quattro...they are the same suspension.
Old Oct 6, 2004 | 04:29 PM
Ghostfire's Avatar
Banned
Default VW golf what year? Or am I taking shots in the dark. I still have the link you first showed me.
<ul><li><a href="http://forums.vwvortex.com/zerothread?id=452388">VW link.</a></li></ul>
Old Oct 6, 2004 | 04:31 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
2nd! Quattro B4 rear is waaaaaaaay different from 2wd rear.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 6, 2004 | 04:32 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default IMO, your first post, is a _shot in the dark_, but........
<center><img src="http://pictureposter.audiworld.com/6607/rearsway.jpg"></center><p>
it is possible to fabricate a rear anti-away bar for the 2wd B4. BTDT!
Like the one pictured.
Old Oct 6, 2004 | 04:47 PM
VAP's Avatar
VAP
Default I would guess you'll have more luck "adapting" a FWD VW chassis car... than having "any" luck...
with an Audi Q-car. I believe the easiest adaptation will come from the Golf/Jetta FWD platforms.
