So...do I really HAVE to drop $200 for a new fuel pump?
Old Oct 6, 2004 | 06:11 PM
SeStone's Avatar
New Member
Default So...do I really HAVE to drop $200 for a new fuel pump?
While doing some maintainence on the fuel system of my car tonight, I effectively destroyed my fuel pump. While trying to get at the check valve to replace it, I put an air ratchet on the big banjo bolt at the end of the fuel pump to try and break it. Unfortunately the check valve slipped first, making the banjo bolt, banjo fitting, and check valve all go spinning...right into one of those contacts that powers the thing. At first only the plastic thing and contact broke off, but then I saw hexes on the contact and started turning, making nothing better *slaps self on head with two $100 bills*.
So...Taylor Auto has the thing for $195. Seeing as it looks like a genericish Bosch part...are there any cheaper models I can look to? Anyone have a spare or used one laying around? I'll check junkyards soon.
Old Oct 6, 2004 | 06:18 PM
YumyJager's Avatar
What car?
Old Oct 6, 2004 | 06:28 PM
egp320i's Avatar
Banned
Default its hard to beat taylor
the only fuel pump is the bosch your looking at or if you can find a peirburg they are a bit less then bosch and as good if not better.
anything electrical costs a fortune, and 200 is about the best your most likely going to find.
Old Oct 6, 2004 | 06:42 PM
SeStone's Avatar
New Member
Default Found something nice:-D... car is a1990 80Q
Turns out all the earlyish quattro era VAG cars until '92 use the same pump, connectors are just mildly different. My buddy has a donor 5000tq that he doesn't need the good pump off of, so hopefully we'll see if it will like a transplant.
Sam
Old Oct 6, 2004 | 06:57 PM
YucatanAudi's Avatar
Look on Ebay for the Pierberg fuel pumps. Usually Shokan has one for about $130.
Old Oct 6, 2004 | 06:58 PM
SLAB's Avatar
Default i have a used one off my 1990 audi 90 20v
i replaced mine because i thought it was bad, and it turned out to be the injectors
you can have it for cheap!
Old Oct 6, 2004 | 07:13 PM
gcarter's Avatar
Default Re: So...do I really HAVE to drop $200 for a new fuel pump?
i did the same thing this this morning. tried super glue, jb weld but i finally broke down and handed over the money. by the way this is my first post. i have been watching this forum for about 2 years now under the radar but i couldn't help but post. just too freaky!
Old Oct 6, 2004 | 07:20 PM
YumyJager's Avatar
Welcome!
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 6, 2004 | 07:31 PM
SeStone's Avatar
New Member
Default Where are you and how much?
Shoot me an email at SamS@racesimcentral.com. Thanks mate:-D
Sam
Old Oct 6, 2004 | 07:42 PM
4corners's Avatar
New Bosch in box for $150 if interested. Been sitting on my shelf for 2 yrs.
