are urethane bushings as hard to press in as OE a-arm bushings?
Old Oct 6, 2004 | 06:56 PM
JazzGuitarist's Avatar
Junior Member
Default are urethane bushings as hard to press in as OE a-arm bushings?
I've got them on my 10v B3 as they came with the car. The rearward front ones are getting some play in them. I was thinking about just buying one for each side and see if it fixes it. I've changed them out on my B4 twice so I know the deal with tightening them with the weight of the car on the wheels. I guess the real question is; will I need to borrow that bearing press from Auto-Zone to deal with the urethane bushings?<ul><li><a href="http://www.tap1.com/Modifications_by_Model/90_quattro__10_Valve_/90_quattro__10_valve_.html">http://www.tap1.com/Modifications_by_Model/90_quattro__10_Valve_/90_quattro__10_valve_.html</a</li></ul>
Old Oct 6, 2004 | 07:23 PM
repeater's Avatar
Default You will still need to use the press.
Put if you chill the bushings, using the press takes very little force to get them in.
TTschwing
18
Nov 27, 2009 09:41 AM
Silvr_Surfr
Apr 12, 2006 04:18 AM
UrSoccer_mobile®
Audi Original "S" Cars
13
Nov 9, 2005 08:48 AM
4kq4snow
Mar 22, 2005 04:12 AM
Sallad
10
Sep 15, 2004 08:33 AM
