Arrgh... I'm going crazy!
Here's what I've done so far:
1. removed negative battery terminal - placed test light in series with negative cable
2. Test light glows fairly bright
3. pull fuses one at a time. At fuse 4, light goes out.
I've cut into the wiring for the rear hatch - no shorts that I can find, and even when the wires are cut, the drain continues.
I disconnected the conections to the anti-theft in drivers side rear side. Drain continues.
I disconnected the radio - still draining.
Checked all interior lights - none on.
Checked ciggy lighter - no obvious shorts.
Any ideas what I should check next? I'm stumped!
Jim
I personally gave up and took it in....I disconnected everything and nothing worked.
