o2 thread size help
Old Oct 8, 2004 | 04:59 PM
egp320i's Avatar
Banned
Default o2 thread size help
who knows the exact tread size of an o2 and the thread pitch?
I need to run a tap through to clean up the opening. thanks
Old Oct 8, 2004 | 05:44 PM
SLAB's Avatar
Default its 18mm....
some old fords used 18mm spark plugs...which are EXACT threads for an o2 sensor...
we have a ford spark plug thread repair kit at work, and it works on o2 sensors as well...
(most newer cars use 14mm apark plugs BTW)
Old Oct 8, 2004 | 06:01 PM
egp320i's Avatar
Banned
Default thanks
knowing that is a big help, i figured the head is 22mm so its going to be around 17/18 or so.
any idea on the threads? they are pretty heavy duty so it should be a course thread then vs a fine thread or does it matter with a tap?
I have never really used a tap before so this is all new to me.
Old Oct 8, 2004 | 07:37 PM
teabagger's Avatar
thought it was 14mmx1.5?
Old Oct 8, 2004 | 08:21 PM
SLAB's Avatar
Default yes it does!
bring the O2 sensor to the hardware store (going to have to look pretty hard to find one with a tap like that) and they can tell you what thread size it is...
OR you can take the old sensor, clean the threads with a wire wheel, and then cut 2 slits 180 degrees apart on the threads themselves and then use that to clean the threads in the exhaust...
OR, take it to a muffler shop and have them do something, because that will be cheaper, and easier than buying an 18mm tap that you will only use once...
Old Oct 9, 2004 | 04:44 AM
VAP's Avatar
VAP
M18x1.5
DS1
Mar 19, 2007 11:26 AM
qpower
Apr 2, 2006 05:56 PM
HarryBauls
Audi Original "S" Cars
Feb 10, 2006 02:51 PM
MelloYelloS4:Indkted
9
Jul 28, 2004 07:07 PM
YellerS4
May 5, 2004 03:24 PM
