to replace the cv boot, do i need to take off the half axle, or can i take it off like other cars...
Old Oct 9, 2004 | 09:34 AM
white90+hibredS4's Avatar
Member
Default to replace the cv boot, do i need to take off the half axle, or can i take it off like other cars...
"press-style"...thanks as always
Old Oct 9, 2004 | 06:14 PM
JazzGuitarist's Avatar
Junior Member
Default I did the outer boots with the axels left on the car
the bolt that holds it all together will also pull the cv joint off. The inner ones, one would need to remove the axel.
Old Oct 10, 2004 | 12:40 PM
90/90Qs's Avatar
Default .
This should be close at least to your procedure. I just did mine 3 days ago, pretty easy, but I recommend removing the shafts. It may be a PITA to drive off the joint while under the car.
https://www.audiworld.com/tech/misc27.shtml
Old Oct 10, 2004 | 02:44 PM
Junior Member
no need to drive off joint, just use the axel bolt to push them apart.
kentcranes
Feb 1, 2010 09:00 AM
Shep 1.8T
Dec 2, 2007 02:41 AM
NiceS4
12
Sep 7, 2006 08:14 AM
benk
Oct 5, 2001 10:09 PM
DavidFeygin
Misc. Models Discussion
Dec 15, 2000 04:30 AM
