Can I use the AHH idler roller on an AFC if I drill the hole to the 10mm ID.
Old Apr 20, 2005 | 02:23 PM
Ghostfire's Avatar
Banned
Default Can I use the AHH idler roller on an AFC if I drill the hole to the 10mm ID.
ECS sent me the wrong part or I ordered the wrong part.
Anyway everything is exactly the same except the AFC has a brim going around the top and has a larger hole in the center. Other then that the roller is the same diameter and the bolt hole just needs drilled. I am just asking because there is no brim and I donâ€<sup>TM</sup>t know if that makes that much of a difference.
Yes that means I got the wrong tensioner pull as well. But I donâ€<sup>TM</sup>t see why I canâ€<sup>TM</sup>t just use the allen key hole in place of the 10mm hole which should be 8mm. I Think I would only have to come u p with a different way of adjusting the tension on the timing belt if I am not mistaken.
Old Apr 20, 2005 | 02:34 PM
VAP's Avatar
VAP
You're opening a can of worms. Do the right thing the first time
Old Apr 21, 2005 | 09:26 AM
Ghostfire's Avatar
Banned
Default Calling up ECS now. I figured I would ask guess it will be another week
since I donâ€<sup>TM</sup>t like paying for overnight delivery. Helps a little because I have a second car to drive. But only one of them has a decent sound stage and itâ€<sup>TM</sup>s the one not running right now.
shadyraven
9
Mar 7, 2024 09:42 AM
gcheddar
Aug 21, 2009 11:41 AM
s4net
10
Mar 28, 2009 07:26 PM
EFresh
Jul 20, 2007 04:48 AM
20VT90q
May 14, 2004 12:02 PM
