Do the front sway bar brackets usually come out easily?
Old Oct 18, 2006 | 09:55 AM
Brdman*'s Avatar
Default Do the front sway bar brackets usually come out easily?
Bolt #23 x4
<img src="http://pictureposter.audiworld.com/37457/front_sway.jpg">
Old Oct 18, 2006 | 10:02 AM
520's Avatar
520
I never had a problem....on 3 cars I did.
Cq20V's Avatar
Came out on mine with no sweat. Use a little penetrant ahead of time if you're unsure.
Old Oct 18, 2006 | 10:04 AM
CvTech's Avatar
Default yeah
but the welded nut that is attached to that notch of the subframe can pop off allowing the bolt to spin. Happened to me bilaterally.
Old Oct 18, 2006 | 10:06 AM
Brdman*'s Avatar
what did you do? run a nut and bolt through?
Old Oct 18, 2006 | 10:14 AM
CvTech's Avatar
Default yup
but there is VERY little space to get a nut or bolt thru. I had a friend plasma cut off one side of that "bracket box" so I can put a nut and still hold it with a wrench. I took just ones side off, the lateral side Its just enough room to get a 13mm wrench in there so you could pinch bolt it down. The old nut just popped right off from the plate. Not sure why or how but it did.
Old Oct 18, 2006 | 10:23 AM
520's Avatar
520
^^^only happens to him! hehe
Old Oct 18, 2006 | 10:24 AM
Brdman*'s Avatar
i beg to differ
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 18, 2006 | 10:39 AM
CvTech's Avatar
Default I know right.
eh, send me those pix if you can or post em up here.
Old Oct 18, 2006 | 11:55 AM
SCarGo02's Avatar
Ditto on the b-chassis cars I've removed them on...
