Does anyone know the diameter of B3 strut tubes? are they same front and rear?
Later strut tubes got swaged under-size, to 50mm/1.969" O.D. and 50mm/1.969" down from their threaded top ends. This swaging process is what many people mistakenly refer to as "2-piece" or "welded" strut tubes and/or other terms. There is none of that in Audi's strut tubes as they are "all" one-piece-top-to-bottom. Then the I.D at the strut top is turned on a lathe so extra wall-thickness and internal deformity that occurs during swaging is removed when external threads are added for the strut caps. The reason for this swaging the tubes is simple... to accept smaller piston/smaller diameter strut bodies (read "lower cost") less performance-oriented strut inserts from the factory. Also it precludes "re-tooling" costs to make smaller diameter strut tubes and hub-mounting jigs/fixtures as well as smaller bore steering arms and lower spring perch ID's.
But the area where all coilover threaded sleeves sit for our cars is 55mm O.D. Thats why the Ground Control C/O kit (58mm I.D.) is such a poor/sloppy fit on our strut tubes, being most likely made specifically for a car, or cars, that use 58mm (or more likely 2 1/4") O.D. strut tubes then being sold as "useable" for the 4kQ (and others) vintage Audi chassis.
I dont specifically remember ordering 2 rear kits but I must've if what you're saying about the 4kQ fronts is true. The way GC does business with "over-sizing" threaded sleeves to us the fronts may have been even closer to a good, snug fit for the 55mm strut tubes if they are as over-sized for a 2" strut tube as the rears are over-sized for a 55mm/2.166" strut tube.
What "may" be happening here is GC is buying schedule "xx" T6 tubing with specific SAE ID's like 2", 2.125" and 2.250" and making all their kits from that as it would severely cut down on machining costs.
