What part is this exactly?
Old Oct 23, 2006 | 03:15 PM
magz's Avatar
Default What part is this exactly?
<center><img src="http://i76.photobucket.com/albums/j9/magz0r/PA230731.jpg"></center><p>Okay, I need to replace this part in the middle of the pic (that the distributor connects to evidently) as the black wire that connects to the hall sender broke off and it's impossible to get a butt connector attached.
What is this part called exactly and where can I get a replacement? I don't own a Bentley and I need to get this POS running before it starts snowing hard.
TIA.
Old Oct 23, 2006 | 03:19 PM
JPCady's Avatar
ummm...that is the distributor
Old Oct 23, 2006 | 03:39 PM
CvTech's Avatar
flux capacitor
Old Oct 23, 2006 | 03:40 PM
magz's Avatar
Default Re: ummm...that is the distributor
Okay, onto stupid question #2: Once I get a replacement, what's the procedure for setting timing on a 10v 5 banger?
Old Oct 23, 2006 | 04:32 PM
teach's Avatar
Not to hijack the thread, but hey JPCady...nice ride! First time seeing it (not in this forum much).
Old Oct 23, 2006 | 06:07 PM
Nkugs90's Avatar
Default don't lie to him...
its the valve cover fan.
Old Oct 23, 2006 | 07:06 PM
JPCady's Avatar
thanks man!
Old Oct 23, 2006 | 07:07 PM
JPCady's Avatar
Not sure about the 10v...but the 20v ecu sets the timing, so all you have to do is get it close.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 23, 2006 | 07:31 PM
BigMouse's Avatar
Default You can replace just the hall sensor unit...
Check out autohausaz.com or bimmerparts.com for it. You'll have to take the distributor apart to to it though. If you can find a used one, good luck finding one without the connector hanging by the wires. Either way, to install, set the engine to TDC on the flywheel ("0" lined up in the window). There might be a seperate ignition mark. I don't remember. Just line it up, then install the distributor so that the rotor is pointing right at the little scribed mark on the housing. Tighten it down lightly and install the cap/wires. Start it up, install a fuse in the fuel pump relay, use a timing light. I forget the setting. Turn the dizzy to get it set and tighten it down good. Remove the fuse from the relay and you're done. Good luck.
Old Oct 23, 2006 | 09:48 PM
Blake@NWAutoSalon's Avatar
Default turbs.
dawg.
Mr Paul [T-28]
Nov 19, 2007 05:21 PM
Mike Atkisson
Audi Original "S" Cars
Dec 29, 2006 01:17 PM
Arson
Rocky Mountain Discussion
Jun 27, 2006 02:01 PM
hAUDIni
12
Oct 27, 2004 01:54 PM
quattro.pilot
9
Aug 27, 2003 08:40 PM
